"2 - I can get the software to recognise COM4 or COM3 ok, but it still shows "controller inactive? "
woodygb wrote:What did you use as the basis for your cable?
Is the controller turned ON ?
woodygb wrote:Is the controller turned ON ?
woodygb wrote:That should work.
I'm getting "Checksum Error Detected" when connecting to an S-Drive using Curtis Program
First...You guys are amazing!! ...I've been doing a lot of reading on these forums.
I assembled cables, as per the recommended connections using FTDI FTS232-RL chips but get an “Initialization of communication interface failed, Checksum Error Detected” message using either the Curtis 1314-4401 or 1314-4402 software.
allbike wrote:Big Thanx woody...
installed the program on my laptop and the program works.
set the program on comm3 and the port also on comm3 no warning message but still is the com inactive..
i,m going to search the forum for solutions haha or maybe i did something wrong with the cable..will do a looptest..
allbike wrote:hello everybody..
No luck yet.. still comms inactive... tried every port..tried 33k and 47k and double checked the diode direction
program does see the port but there's no communication with the chair
the usb chip i'm using is the ch340g....( https://www.conrad.nl/p/joy-it-sbc-ttl- ... -m-2149077 )
is it possible that i got to use the fdti ttl with an fdti chip?
woodygb wrote:Try without the 5v & resistor.
Users browsing this forum: Burgerman, faico_26 and 360 guests
