Scooterman wrote:Are lugs available that can accommodate a large diameter cable but still have only an M4 bolt clearance hole?
The reason I ask is usually the larger the cable size the bigger the lug bolt clearance hole?
At least that's the way it tends to be in the UK but I'm only familiar with power/mains electrics so perhaps automotive lugs are different? But then it seems everything is available in China. Some of the stuff you post Shirley you'd never get over here.
Can I have a link to accurate measurements of those 105Ah cells?
Burgerman wrote:Lugs...
Ring terminals?
shirley_hkg wrote: They are not perfectly flat. I will pile them up and measure the thickness of 8 cells.
Scooterman wrote:Burgerman wrote:Lugs...
Ring terminals?
That's true you're right they are ring terminals, I don't know why I call them lugs? I think I probably learnt it from the old boys at work when I was an apprentice. Just like foolscap sheet paper, I always assumed they meant A4 sheet but I never did discover.
shirley_hkg wrote:shirley_hkg wrote:LROBBINS wrote:Clearly that device is unsuitable, but I do wish someone could find a cell balancing board that would: (1) start balance only near or at the end of CV, (2) dissipate or exchange enough current to balance reasonably quickly (would 3A be enough?). It should be rugged enough to be mounted in the chair and not need any user attention (after initial programming). As it would only be doing something when connected to a charger, it can be a passive balancer that just dissipates energy from the highest cell - the mains watt-hours wasted would be tiny in any case.
You will get one , very soon.![]()
This new breed of BMS I mentioned earilier in page 162 , is available now. I need to change the power module to a 18Vdc---36Vdc , 5V / 5A one for our application.
Which model will fit ?
Burgerman wrote:900 for 40Ah usable from gel.
500 for 210 all usable from Lithium, with 7x the lifespan, and 5x the range, just over half the weight...
I will be ordering a set of those very soon.
Burgerman wrote:Shirley tested a set. Full capacity. Low resistance for a high capacity low C rate type cell, and consistent. Only negative is the small M4 thread. But if you are not ham fisted and understand what you are doing that need not be an issue.
stevelawiw wrote:
If enough of us want them at the same time could we perhaps order a pallet?
Users browsing this forum: No registered users and 66 guests
