DWIZ-ADAPT
Re: DWIZ-ADAPT
Postby woodygb » 22 Aug 2019, 22:23
Not a clue ...sorry.
Re: DWIZ-ADAPT
Postby Irving » 22 Aug 2019, 22:34
GlennGlenn wrote:Woody
Further to my question about the caps and theie orientation, I think that if a polarised capacitor is used for C1 its +ve must go to ground.
A negative voltage is taken from the Tx terminal (Rx) and stored in C1. The -ve is used for sending RS232 high from Rx rerminal (Tx).
This is a way of level matching the return -ve voltage to the received one irrespective of what shifting and combination is done by the rest of the adaptor before it goes to remote.
I think I should invert C1 before my RS3232 arrives, do you agree?
Glenn
The ground end of c1 should be +ve. C1 and the diode create a TX driven charge pump to provide a -ve reference for the RX circuitry.
Re: DWIZ-ADAPT
Postby GlennGlenn » 23 Aug 2019, 00:48
I came to the same conclusion after studying various circuits.
Thanks for the response.
Glenn :thumbup:
GlennGlenn
Re: DWIZ-ADAPT
Postby kaban » 10 Nov 2019, 20:12
Hi guys, am newbie here. Can anyone PM me a link to the Wiz5 software please?
kaban
Re: DWIZ-ADAPT
Postby kaban » 19 Apr 2020, 20:54
Hello again,
I've installed Wizard 5 as described by Burgerman.
I don't get Asked for any Password and I can change the user mode (Service etc.).
Then I connected a RS232 to usb converter from the programming Plug to the PC, didn't work out.
Tried it with a CH340, didn't work as well.
With a CP210x it neither worked.
Did I miss something out? :problem:
kaban
Re: DWIZ-ADAPT
Postby kaban » 19 Apr 2020, 20:55
By the way: I've got a G50 with a DX. Remote has directly got programming port in it, like woody posted somewhere here.
kaban
Re: DWIZ-ADAPT
Postby kaban » 19 Apr 2020, 21:21
If I send anything to the programming port via a Arduino @ 38400 Baud with SoftwareSerial, I get this answer from Joystick: 1202481281202480 o.O
@ 19200 I get 1020
kaban
Re: DWIZ-ADAPT
Postby woodygb » 19 Apr 2020, 23:31
The 5 pin Hirose port communicates via RS232 SERIAL as opposed to TTL SERIAL.
https://www.sparkfun.com/tutorials/215
Any QUALITY RS232 SERIAL cable ( e.g. one that uses a FTDI Chipset ) should work fine.
E.G. https://www.amazon.co.uk/COOSO-Serial-F ... 172&sr=8-4
Re: DWIZ-ADAPT
Postby woodygb » 19 Apr 2020, 23:42
Re: DWIZ-ADAPT
Postby kaban » 20 Apr 2020, 08:07
Thank you for the answer.
I think the Problem is in the Software..
Would you send me a PM with all the DL links In need?
kaban
Re: DWIZ-ADAPT
Postby woodygb » 20 Apr 2020, 08:45
kaban wrote:If I send anything to the programming port via a Arduino @ 38400 Baud with SoftwareSerial, I get this answer from Joystick: 1202481281202480 o.O
@ 19200 I get 1020
All Arduino boards have at least one serial port (also known as a UART or USART), ... Serial communication on pins TX/RX uses TTL logic levels (5V or 3.3V ...
You need RS232 Serial.
Re: DWIZ-ADAPT
Postby CarbonTech » 26 Apr 2020, 13:08
Hi guys, I am new here. Would someone please PM a link to wizard 5 software?
CarbonTech
Re: DWIZ-ADAPT
Postby Burgerman » 26 Apr 2020, 16:46
Check PM
Re: DWIZ-ADAPT
Postby Khalid » 16 May 2020, 21:01
Hello everyone ,new member here, hope everyone is doing well, so my neighbor got a mobility scooter which has the rhino dynamic 70 amp controller(ctldc1343/ DS72KSP02) im willing to help him out programming it to his special needs, so i was wondering if you guys would help me get the proper software which i believe needs to be a oem version in order to read and write and making the proper usb cable to plug it to the laptop.
Khalid
Re: DWIZ-ADAPT
Postby woodygb » 16 May 2020, 21:10
You need a RS232 ( DB9 )-USB Cable ...I prefer any that uses a FTDI Chip set.
E.G. https://www.amazon.co.uk/DSD-TECH-SH-RS ... B07MYYCMJT
Als0
3 of these........https://www.amazon.co.uk/DSD-TECH-SH-RS ... B07MYYCMJT
and the software.
Re: DWIZ-ADAPT
Postby Khalid » 16 May 2020, 21:37
Thank you woody for the fast reply and for the pm! ,so what i understand is that i just need this usb rs232 cable connecting just those 3 pins tx dx and gnd to the controller and it will read on the laptop? No special dongles or anything?
Khalid
Re: DWIZ-ADAPT
Postby Khalid » 16 May 2020, 21:44
Also i was wondering if i connect everything i just have to turn on the scooter with the key right? not adding any other power wire to the programming connector like pg drives do. Would these boards im gunna attach might work instead of this cable by any chance, because i already i have them
Khalid
Re: DWIZ-ADAPT
Postby Khalid » 16 May 2020, 21:45
And this
Khalid
Re: DWIZ-ADAPT
Postby Irving » 16 May 2020, 21:51
Khalid wrote:Also i was wondering if i connect everything i just have to turn on the scooter with the key right? not adding any other power wire to the programming connector like pg drives do. Would these boards im gunna attach might work instead of this cable by any chance, because i already i have them
You can probably make that work...
Re: DWIZ-ADAPT
Postby LROBBINS » 16 May 2020, 22:44
Dynamic systems normally require a dongle for programming, but there's a workaround that can get you into an OEM-plus mode without one. When you're ready to go, ask here and someone will PM you with the information you'd need. The software itself is downloadable from the Dynamic web site.
Re: DWIZ-ADAPT
Postby woodygb » 16 May 2020, 23:10
As Irving say's ... yes it should.
Just remember that the connection convention is TX of one board goes to the RX of the other .
Re: DWIZ-ADAPT
Postby Khalid » 16 May 2020, 23:18
Thanks for the help ,will try and see what happens
Khalid
Re: DWIZ-ADAPT
Postby Khalid » 21 May 2020, 12:00
Hey woody so i did everything as told but cant get the controller to connect to the laptop, i used this board i will attach a pic, and i have the oem program, i have the solo d50529/1 ,tried changing the com ports didnt work just this time i didnt get the cant open serial port message but still said comms inactive, used a 47 k resistor and a 1n4148 zener, what can be the problem?
Khalid
Re: DWIZ-ADAPT
Postby Khalid » 21 May 2020, 12:08
Khalid
Re: DWIZ-ADAPT
Postby woodygb » 21 May 2020, 13:41
Your going to confuse things by posting your Solo question in this Dwiz Adapt thread.
I will move/copy your question to where you had previously posted it.
Re: DWIZ-ADAPT
Postby cata300 » 29 May 2020, 20:11
Hello guys, I am new here.
Could someone please PM me with a link to the Wizard 5 software?
Thanks!
cata300
Re: DWIZ-ADAPT
Postby Burgerman » 30 May 2020, 08:58
Did you find it?
Re: DWIZ-ADAPT
Postby woodygb » 30 May 2020, 08:58
Yup
Re: DWIZ-ADAPT
Postby cata300 » 31 May 2020, 20:35
It works.
Thanks a lot for the instructions!
cata300
Re: DWIZ-ADAPT
Postby znachor8 » 22 Jun 2020, 15:18
Hi guys, I am new here. I use Storm 4 every day, I would like to try to improve some parameters. Would someone please PM a link to wizard 5 software?
znachor8
Users browsing this forum: DennisinTexas, duke1, emilevirus and 313 guests
