Shirley has said he can get 16 105ah batteries for around £500 but postage so far is prohibitive.
16x of the 90Ah cells was £890 to my door including all fees.
PL8 and some leads £250 by the time HMRC had their slice too.
Around another £180 on bits and bobs.
We already had soldering and crimping equipment covered but you may need an iron, etc.
Had to have a new battery box welded up. Cost to me £0 as my dad did it from stuff he already had, but factor that in if your measurements turn out to be too tight.
Insulation material. Also came from the stuff my dad already had but whatever you order won't be free.
£50 worth of lead to go at bottom of chair and restore centre of gravity as cells lighter than batteries.
Power supply - no idea it was also from the stuff my dad already had.
foghornleghorn wrote:PL8 and some leads £250 by the time HMRC had their slice too.
foghornleghorn wrote:£50 worth of lead to go at bottom of chair and restore centre of gravity as cells lighter than batteries.
shirley_hkg wrote: It is a good price you've found.
Won't need those bus bars & bolts.
Use what I posted here before.
And here is the real things, in page 163 of this thread.![]()
Dan wrote:shirley_hkg wrote: It is a good price you've found.
I'm not so sure the price is that great BUT than again the pound is quite weak at the minute.
OK no busbars but rather;
Crimped cables
M4 stainless steel studs bar with Loctite 2700
Stainless steel nyloc nuts
Irving wrote:£1200 now with a 10y life span still looks a good deal
Irving wrote:An alternative, and arguably neater, wiring scheme.
Scooterman wrote:Internal Resistance is a good indicator of how good the connections are.
Do you bother checking it?
I rarely charge with the laptop connected as it ties up the laptop for a few hours.
I just use shirley's PSU and the PL8.
When charging I do check the IR on the PL8.
For those of you who've had lithium installed for a while is there an IR reading that the cells should stayed below?
For example 5 milli-ohm?
The larger cell specs usually state a cell value of say 0.5 milli-ohm.
Just curious...
saker98 wrote:3.2V 105Ah
Weight : 2.05kgs
Cell rate : 3C
Users browsing this forum: Burgerman, emilevirus, Gregrb and 1013 guests
