R-net
Re: R-net
Postby foghornleghorn » 06 Jun 2019, 19:30
I was doing ok until I got to the graph and now i'm czy
Re: R-net
Postby Burgerman » 07 Jun 2019, 05:16
That applies to ALL permanant magnet DC motors.
It basicaLly just says that at any constant voltage:
All DC motors at constant load and so constant RPM take the MAX Amps when stopped (stalled) and produce the most torque when stopped. And obviously are wasting 100% of the power so at this point 0% efficiency... Because you are going nowhere and burning max Amps!
As the are allowed to get faster (still at constant but reducing load to hold RPM at x) the Amps falls away. The torque falls away. The efficiency increases.
At max continuous RPM (so zero load) a motor would pull zero Amps. But theres air (windage) losses, brush friction, bearings. So in reality there a small non zero current. But here efficiency is also zero since theis is doing no output, no load, and so 0% efficient.
This is because a motor is also a generator. The faster a motor spins, the more VOLTS it generates. When this matches the supplied voltage then no more current can flow.
Re: R-net
Postby Burgerman » 26 Aug 2019, 10:58
Bump... Since a few are all asking permobil or r-net questions.
Re: R-net
Postby hank » 07 Sep 2019, 20:22
Just bought a spare R-net 120amp PM £45 Delivered.
I see Burgerman bought one for same price.
Anybody got one any cheaper to beat us ;) czy
Re: R-net
Postby Irving » 07 Sep 2019, 20:35
hank wrote:Just bought a spare R-net 120amp PM £45 Delivered.
where/how...? :? :( been watching on ebay.... not seen anything that cheap..
Re: R-net
Postby Burgerman » 07 Sep 2019, 20:38
No. I buy them fast! :clap
Rover sold me one cheap, not ebay cheap but fair. Also watch for permobil not r-net or 120A. Because they dont know the difference. And US ebay.
Re: R-net
Postby Irving » 07 Sep 2019, 20:45
Burgerman wrote:No. I buy them fast! :clap
Been doing all of that... :( :(
(I've got 2, but figured a 3rd can't hurt if price is right)
Re: R-net
Postby hank » 07 Sep 2019, 20:47
Blink and you miss them like John says czy :shock: :dance
Re: R-net
Postby Irving » 07 Sep 2019, 21:23
Just picked one up for £70 delivered, ok not £45 but cheap enough...
Re: R-net
Postby Burgerman » 07 Sep 2019, 21:24
70 is still cheap. The local dealer will charge you phone numbers...
Also, tom at the powerchaircompany has some brand new latest colour joysticks going at the right price. 125?
Re: R-net
Postby Irving » 07 Sep 2019, 21:32
i asked Tom b4, he said he couldn't at that price :(
Re: R-net
Postby Burgerman » 07 Sep 2019, 21:36
Oh. Maybe because I bought 2. Or has no spare ones left. He only wanted the generic ones for his chairs, and was selling the ones that said sunrise, quickie, on boot up. And elryko1992 is selling these new as well.
Re: R-net
Postby Irving » 07 Sep 2019, 21:44
yes, at 300... i'm not that desperate :D
Re: R-net
Postby Burgerman » 07 Sep 2019, 21:51
He will go cheaper if you fight him! I know. :fencing
Re: R-net
Postby Irving » 09 Sep 2019, 10:29
One in Texas for £73 but might not ship to UK
https://www.ebay.co.uk/itm/PG-Drives-Pe ... 4309065810
Re: R-net
Postby Dan » 09 Sep 2019, 11:01
I thought the Permobil stuff was a bit of a pain in the arse?
Dan
Re: R-net
Postby Burgerman » 09 Sep 2019, 11:32
It is. They use R-net joystick, and Power Module. But they use THEIR OWN seating module and gyro module... So dont buy those. Buy the ISM6 instead. They use these rather than the R-Net ones. And that requires a cable we dont have and some software called wheelchair builder that they use to configure this seaing. They even have the cheek to say that the fancy colour joystick is "their: design! Its not. They also use permobil rnet software rather than generic software. That is needed to adjust their own gyro, and seating options etc.
Re: R-net
Postby Furio » 02 Oct 2019, 15:22
Is there a way to take out the contacts from R-net motor connector casing? Also any tools for the same .
Any advice appreciated.
Furio.
Furio
Re: R-net
Postby Irving » 02 Oct 2019, 23:08
Furio wrote:Hi,
Furio.
Anything is possible, what are you trying to achieve?
Re: R-net
Postby Burgerman » 03 Oct 2019, 00:00
I did it once. Dont remember how, years ago on a pilot plus which is the same setup. Two long thin screwdrivers and a load of struggling and swearing is all I remember. PG will sell you new ones.
Re: R-net
Postby Burgerman » 05 Oct 2019, 17:27
Bump..
Re: R-net
Postby Furio » 06 Oct 2019, 14:27
BM,
Sorry. First, it is a PITA ordering from PGDT, for almost always they come up asking to buy from OEM, which is not my case. Secondly, if they deem to sell, for a couple of connectors costing US$ 15-20, the courier charge alone will be(they send only by DHL) US$ 60-70.
Furio
Re: R-net
Postby Burgerman » 06 Oct 2019, 14:49
Then you have 2 choices.
Try to bodge it and reverse engineer it, or use blade connectors.
Buy the motors or battery leads from a powerchair as required.
Re: R-net
Postby ex-Gooserider » 08 Oct 2019, 02:46
Furio wrote:Hi,
Furio.
There probably is a tool, good luck finding it, and then figuring out which testicle you want to sell to pay for it...
However like many connectors the contacts basically lock in with a small tab sticking out the side of them. A thin jewelers screwdriver slid in along side the contact in the right place will bend the tab in enough to slide the contact out. Careful examination of the plastic housing will usually show a notch where the tab slides in, you will want to push the screwdriver in from the opposite end to bend the tab down and pull the contact out - often it helps to do both at the same time...
Re: R-net
Postby stefanturbo » 18 Oct 2019, 16:04
Where can I buy a Omni 2?
stefanturbo
Re: R-net
Postby Burgerman » 18 Oct 2019, 16:15
Its possible that rover on here may have one, and other than that PGDT directly, or eBay used now and again.
Re: R-net
Postby rover220 » 18 Oct 2019, 16:30
sadly i dont have one at the minute, i may be able to get one but they are not cheap.
Re: R-net
Postby flagman1776 » 18 Oct 2019, 16:58
Way back when I was an electronics technician, I used to have tools for removing contacts from specialized connectors. Some were round, others flat. Yes, there must be some sort of an expanding retainer. The tool would try to compress that. I'd suggest examining the connector under a lot of magnification to see what you are going after.
flagman1776
Re: R-net
Postby Burgerman » 23 Oct 2019, 21:31
Just bought another complete R-Net system, 120A power module, 6 chanel ISM, buss cables, and a cheap joystick that says pride on it (spits)...
150 + 6 delivery.
A link posted in the buy sell, for eBay. Thank you! https://www.ebay.co.uk/itm/123950029166
Thread. viewtopic.php?f=1&t=9273&p=147088#p147088
What can I say. This stuff DOES come up and at the right price if you wait. And are FAST to buy before you miss and its no longer visible.
I now have 4 complete 120A systems, and with 3 advanced colour joysticks, and this cheap nasty one...
Re: R-net
Postby steves1977uk » 24 Oct 2019, 10:57
That's a bargain BM! :thumbup:
Users browsing this forum: emilevirus, Juggler258, Seafighter, Superchunk and 493 guests
