Burgerman wrote:Can you give the overall dimentions of the pack as seen W x L x H?
Actually that should read 200Ah, 12V as its a single lead brick box right?
Burgerman wrote:If they were 3C then you CAN take 300A from them. Max. But they will last a month to a year if used daily maybe - thats a guess, too many variables.
If they are 3C and you take 100A from them, (a third of their max rating) maximum, they will last years.
But in your lightweight case, stripped down chair, light user, you may be OK. Because battery amps are usually much lower than motor Amps.
But I thought these were 1C cells, with only 3C pulse rating (a second or so).
shirley_hkg wrote:goodpost
EVE-LF90 , Rated --- 3C (5C max) ; IR @ 0.5mΩ .
Scooterman wrote:Has anyone built a lifepo4 pack using cells with an M4 threaded hole?
If so how did it go?
Burgerman wrote:But those are a difficult size that does not fill the battery compartment? They are lower, mostly.
shirley_hkg wrote: One A grade cell costs £70 brand new. Itsn't difficult to understand , is it ?
Users browsing this forum: JMGarage, LROBBINS, martin007, Raro and 129 guests
