Postby rover220 » 04 Dec 2019, 10:50
do you have good head control, they gyroset is great but you need good repeatable movements to get the best from it.
Postby duke1 » 26 Dec 2019, 15:12
hi all has anyone have experience of this new system on the invacare range?
can we alter it easy or not :dance cheers
https://invacarelinx.com/edo-en/#easy-to-personalise
duke1
Postby Irving » 26 Dec 2019, 15:25
duke1 wrote:hi all has anyone have experience of this new system on the invacare range?
Don't know of anyone who has it. Looks like it follows a bus-like system similar to R-Net but how open it is remains to be seen...
Postby steves1977uk » 26 Dec 2019, 15:38
I'm guessing it's a rebrand of the locked down Dynamic LiNX system, best to avoid at all costs!
Postby steves1977uk » 26 Dec 2019, 15:47
Actually I turned down a powerchair from Norwich WCS, because guess what they supply... Yep, you guessed it, Invacare chairs with the Dynamic LiNX system which is locked down to hell! :fencing
Postby duke1 » 26 Dec 2019, 15:58
cheers for replies well maybe i shall have to bribe the wcs dude to reprogram it if i slip him a few sheckles czy good job its only for indoors/hospitals just so they dont throw it out as she was quite cross! :fencing :fencing :fencing :evil: happy hols all cheers :joint
duke1
Postby Burgerman » 26 Dec 2019, 19:51
several issues. One they wont do it. And dont have a clue how to make it steer. And they are all jobsworths. Run away. You want r-net. You dont want any invacare modern chairs they all have the same problem. Which means they are useless. Its all locked down unless THEY fix it. Rover may help.
Postby steves1977uk » 27 Dec 2019, 18:09
ISTR Rover mentioning he couldn't get a powerchair with the LiNX control system to steer properly, because there was no way to unlock the OEM settings. Basically Dynamic/Invacare wants to lock down their system as much as possible so it seems. :roll: :cussing :fencing
I'm avoiding any powerchair that comes with the crappy LiNX setup and go for a chair with R-net.
Postby terry2 » 30 Dec 2019, 09:33
Hey guys.
Can someone who has the new large screen controller tell me if the profile button can go up and down the profiles please.
Like on my old DX2 I could go 1-2-3-4-5 or 5-4-3-2-1
On my new R-Net system. It won't go down. So I have to stop, then cycle through the profiles.
Postby rover220 » 30 Dec 2019, 11:32
terry2 wrote:Hey guys.
no the right speed paddle can only adjust speed if the parameter is enabled in programming. profiles only step up not down regardless of programming.
Postby duke1 » 30 Dec 2019, 14:13
Burgerman wrote:several issues. One they wont do it. And dont have a clue how to make it steer. And they are all jobsworths. Run away. You want r-net. You dont want any invacare modern chairs they all have the same problem. Which means they are useless. Its all locked down unless THEY fix it. Rover may help.
see you need the right sort of bribe! :joint delivered and basic reprogram and my tina took it down to the park and back then manoevered through the house passed the other chairs and says it steers fine now and adequate for hospitals and indoors at home and maybe if she has no other choice round to local shop might be ok,still silly sticky out corner smashers and sloppy meccano swingaway but there coming back to change it to a fixed one,there seems to be no mounting points for a centre footplate and she will have to get used to the extra set of casters,crash,crash, another hole in a door or wall banghead
the hardest bit will be not being allowed to modify it!
and yes whilst the so called wheelchair therapist understands little of the real important things he did listen and said that i obviously knew more about the chair than he did and his knowledge of the program is limited to dealer so only basics but enough given the right bribe to make it steer,some people will not be bribed with money or beer but a little wacky baccy goes a long way! :thumbup:
duke1
Postby steves1977uk » 30 Dec 2019, 15:01
duke1 wrote:yes whilst the so called wheelchair therapist understands little of the real important things he did listen and said that i obviously knew more about the chair than he did and his knowledge of the program is limited to dealer so only basics but enough given the right bribe to make it steer,some people will not be bribed with money or beer but a little wacky baccy goes a long way! :thumbup:
But there's your problem, the tech won't be able to improve the steering because the values are locked in the OEM settings, unless you can convince Invacare to give you the OEM tools you need to be able to set it up correctly. Or tell WCS you're going to retrofit a PGDT control system that will allow you to set it up properly, ignore their BS rules and modify it like BM did back in 1997.
Postby duke1 » 30 Dec 2019, 15:25
hi steves well she is happy enough with the way it steers and thats the main thing theres def no delays in steering now its ok.
just glad she is not forced to use it full time she is def more comfortable with the old gunter meire chair for outdoors and i shall fix the mudmonster soon it ate its lefthand cush drive but not surprised as she has tortured it proper rough of roading sure does that! allegedly wcs only allowed dealer status re programming which seems daft but normal for here.i think she would kill me if i start taking the grinder to the wcs chair but its tempting,those awful footrests be first for the bin!!!!!!! banghead banghead banghead :ak47 cheers
duke1
Postby rover220 » 30 Dec 2019, 15:49
I fear you are forgetting not all are as capable as BM when it comes to modding or retrofitting control systems.
Postby Burgerman » 30 Dec 2019, 15:58
Wrong! Thats the problem, you have nothing to compare it to that goes where its told.
Postby steves1977uk » 30 Dec 2019, 18:30
rover220 wrote:I fear you are forgetting not all are as capable as BM when it comes to modding or retrofitting control systems.
I realise that rover, but it can be done with the correct plugs/connectors and tools. Also an OEM programmer.
Postby duke1 » 30 Dec 2019, 18:42
hi bm we have the 2 other reprogrammed to your settings chairs so i think we are ok as long as she is happy is all that matters though yes i do wish wcs chairs still used pg drives but being as its wcs we do not get a choice but like i say its for indoors and hospitals so will seldom be used hopefully outside our house,being midwheel drive it will be utterly useless round here anyhow! :lol: cheers
duke1
Postby rover220 » 30 Dec 2019, 18:43
your average chair user would not manage it nor would they be able to get required connectors and almost certainly not oem programmer
Postby terry2 » 02 Jan 2020, 12:40
Thanks for the info.
Just paid for my R-Net OEM programmer from curtiss wright.
They are bloody cheap until you add shipping and VAT booooooooo :lol:
Postby Burgerman » 02 Jan 2020, 13:29
Adding 20% to everything we buy is how we get the free socialist NHS. :clap
Postby steves1977uk » 02 Jan 2020, 23:52
terry2 wrote:Just paid for my R-Net OEM programmer from curtiss wright.
I thought Curtiss-Wright didn't sell OEM programmers to us end users? :? Have they woken up and realised those that know what they're doing can buy them directly from CW without having to use a third-party? Or did Terry order from PSS? :shh:
Postby Burgerman » 03 Jan 2020, 02:29
They will sell if you sound like you know what you are talking about. Ask me how I know... Also power modules, joysticks, etc. Ask a dumb question, or sound like an end user and nope...
Postby terry2 » 03 Jan 2020, 09:06
I signed up for a account with them.
Then ordered a OEM over the phone. They are only £154 +shipping and vat
Postby Burgerman » 03 Jan 2020, 11:10
I have an account since 98. They wont supply end users but if you are a business then no prob.
Postby terry2 » 03 Jan 2020, 13:27
Burgerman wrote:I have an account since 98. They wont supply end users but if you are a business then no prob.
And yet they did :lol:
Gift of the gab me :D
Postby steves1977uk » 03 Jan 2020, 14:29
Surprised you had to pay VAT Terry, as when I order spares from CW they usually send me a Pro-Forma for VAT relief. So I'd pay £154+£10 P+P if I ordered one. :mrgreen:
Postby terry2 » 03 Jan 2020, 16:29
The delivery was £35 for some reason.
I won't get it till after the 14th.
I may just have a play then sell it.
Postby steves1977uk » 03 Jan 2020, 16:38
£35 delivery! :o How on earth is it that much? czy I wouldn't sell it because you never know when you might need to re-program another chair with R-net. Or a friends. :thumbup:
Postby hank » 03 Jan 2020, 16:43
Bargain of the year Terry :dance :clap :clap
Postby rover220 » 03 Jan 2020, 18:05
delivery is a flat fee no matter what they ship, ridiculous frankly as royal mail special delivery could be done for under £9
Users browsing this forum: Juggler258, LROBBINS and 552 guests
