I wouldnt ever use royal mail. I lost count of the times I WATCHED he driver, never got the parcel out of the van (takes too long) knocked on my unlocked door lightly so a mouse wouldnt hear it, and instantly posts a PRE WRITTEN note that says "sorry we missed you". By the time I made my front door, literally 6 seconds from my room, the driver was gone, and so was the van. Over and over. For years.
So I pinned an A4 sheet of paper to the outside of my door bang in the centre. It says, PLEASE KNOCK, IF NO ANSWER ENTER FOR SIGNITURE. Or LEAVE PARCEL INSIDE FRONT DOOR OR IN OUTER PORCH. Which every other parcel company does. But not Royal Mail who think its much faster ad easier for the driver to just deliver notes that ask you to collect from post office. Save them time and they dont have to bother getting the parcel out.
Worse, anything from overseas gets delayed. While they hold you to ransom for any charges, and after an additianal week you will recieve a 2nd class letter asking for the money. Which includes an aditional £8 or more for the privelidge of them collecting it from customs. The other companies just deliver. Then bill you (less) later. ut not royal mail or parcel farce.
Dont use them. They are scammers and dont do the job properly, and they hold you to ransom. Hermes for cheap, and DPD for performance and unbelievable tracking.
terry2 wrote:Hi all.
Is the joy stick with the 3.5 inch a PG Drives R-Net D51715.01 here in the UK?
Can the hare and tortoise switch be re-programmed to up\down profile switch instead?
Burgerman wrote:You will be missing many things. I just looked. That file is DEALER level.
terry2 wrote:Burgerman wrote:You will be missing many things. I just looked. That file is DEALER level.
The CD had the 6.1.0 OEM software which I installed.
On the back of the dongle it says D50609,03 and in the little box on the bottom right is an A
How do I unlock it or should I send it back?
Just checked and yes they have sent me the dealer version
But I told them I build my own chairs and needed OEM access to set them up properly! expresso wrote:either they put the wrong dongle or thats the only one they will sell you ? i wont be surprised if that were the case - based on the cost alone they charged you - but worth it to call them and find out - worse case i would still keep that dongle - because you can still make use of it with OEM software -
steves1977uk wrote:terry2 wrote:Burgerman wrote:You will be missing many things. I just looked. That file is DEALER level.
I told you you wouldn't get an OEM dongle that cheap! Manufacturers only sell Dealer level dongles to us end users.But I told them I build my own chairs and needed OEM access to set them up properly!
Who did you order the dongle from? Meyra or Curtiss-Wright?
Burgerman wrote:If you use the OEM PC software, you can CONVERT your DEALER level file, the one on here, to an OEM one. Then you can see and edit everything. Then you can save that back to your desktop, and write that with the DEALER dongle to the chair regardless. Should you want. I used to do that, then got an OEM dongle to save the extra steps.
Burgerman wrote:Your DEALER dongle marks the file DEALER.
If you see at the bottom it says file: dealer.
If you then save that to the desktop with a new name like OEM1 and then shut down. The OEM software marks the file OEM.
Then, Re-Open that file with the RE OPENED OEM software again, you will see its now an OEM file. And more options...
Disconnect the dongle from the PC else the next step appears to work but doesn't always (or in my case, never)
Users browsing this forum: LROBBINS, saker98, Seafighter, sergey0 and 559 guests
