Burgerman wrote:It should be plug and play. But some of its feature can be programmed and you would probably want to do that.
Burgerman wrote:No, you must buy. You can get away with a dealer one as theres a workaround that allows OEM access regardless.
steves1977uk wrote:The workaround is the following steps:-
1. With the Dealer dongle connected, save the settings from the chair using either Dealer or OEM programming software. Save the file with an easy name, e.g. Dealer.r-net
2. Disconnect Dealer dongle and open the Dealer.r-net file in the OEM software. Do not make any changes at this point and just re-save the file with a dfferent name, e.g. Dealer_OEM.r-net and then close the software.
3. Re-open the OEM programming software and load the Dealer_OEM.r-net file. Make the required changes and save as a different name if you like.
4. Re-connect Dealer dongle and write your new settings to the chair. Job done!
Hope this helps,
Users browsing this forum: Burgerman, saker98 and 402 guests
