GlennGlenn wrote:Woody
Further to my question about the caps and theie orientation, I think that if a polarised capacitor is used for C1 its +ve must go to ground.
A negative voltage is taken from the Tx terminal (Rx) and stored in C1. The -ve is used for sending RS232 high from Rx rerminal (Tx).
This is a way of level matching the return -ve voltage to the received one irrespective of what shifting and combination is done by the rest of the adaptor before it goes to remote.
I think I should invert C1 before my RS3232 arrives, do you agree?
Glenn
kaban wrote:
Then I connected a RS232 to usb converter from the programming Plug to the PC, didn't work out.
Tried it with a CH340, didn't work as well.
With a CP210x it neither worked.
Did I miss something out?
kaban wrote:If I send anything to the programming port via a Arduino @ 38400 Baud with SoftwareSerial, I get this answer from Joystick: 1202481281202480 o.O
@ 19200 I get 1020
All Arduino boards have at least one serial port (also known as a UART or USART), ... Serial communication on pins TX/RX uses TTL logic levels (5V or 3.3V ...
Khalid wrote:Also i was wondering if i connect everything i just have to turn on the scooter with the key right? not adding any other power wire to the programming connector like pg drives do. Would these boards im gunna attach might work instead of this cable by any chance, because i already i have them
Users browsing this forum: duke1, LROBBINS, Superchunk, ukralex and 356 guests
