woodygb wrote:This diagram might make the connections clearer....I have removed the confusing + and - signs from the SB50 plugs at the connection point.
The yellow is the middle connection between the 2 off 12v batteries...wired like this in SERIES you get 24v.
optical10 wrote:Guys i'm getting a bad rotten egg / sulfur odor from the Salsa r2 two original 60 Ah BATTERY ETERNITY G 04 12 055 whilst charging! Also they loss charge immediately after a charge.
Have I damaged a cell beyond a recovery even with a deep long charge with this charger at
"12A
,28.20V
.3A
27.0V" over a week or am I wasting my time [the smell indoors is killing me] so should think about Lithium replacement mod?
Burgerman wrote:Easy check. Stick a voltmeter on the two wires you are about to charge. If its around 12 to 13 then thats one batter. If its 24 to 26 the thats both in series.
I expect that battery to be deformed. Bulged. Distorted.
steves1977uk wrote:optical10 wrote:Guys i'm getting a bad rotten egg / sulfur odor from the Salsa r2 two original 60 Ah BATTERY ETERNITY G 04 12 055 whilst charging! Also they loss charge immediately after a charge.
"12A
,28.20V
.3A
Did you set the ZXD2400 PSU into 3-stage charge mode? If so, then the current should drop to the termination point unless the batteries are completely knackered.
LROBBINS wrote:You will want the 0-60V, 0-50A. You can use either the "electronically-modified in original case", or at the cost of some more work re-mount that in the "fancy" aluminum case (the latter may require extending the wires to the display board). If the noise of the fans bothers you, it is possible to substitute them with quiet, thermostatically controlled fans, but that's also DIY.
Burgerman wrote:Like the shirley one? Yes. Price is a little extreme.
The other one? Who knows...
LROBBINS wrote:What Burgerman said. Price does include DHL shipping. That one already has the fancy case, so the only thing you might want to add is an Anderson socket - not very difficult. Also has the one in original steel case for a little less - $248.
Burgerman wrote:When they were cheap, I bought 2 just in case... Obviously!![]()
Half of that price but needed assembling into the fancy case (DIY way).
Both were easy and have been well behaved so far. Programming takes a little learning and isnt very intuitive. Till you finally get it. Then it just clicks and is all obvious! Also hard to explain.
expresso wrote::thumbup:
Users browsing this forum: Burgerman, Pierro, shirley_hkg and 100 guests
