Burgerman wrote:Its a SM3040 30V set to anything from 12 to 28 depending on what I am doing.
I bought those on eBay, they periodically come up as "refurbished" or demo units. Cheap. I bought one demo, one refurbished. Both were effectively new in box with new cables etc all sealed up in polythene. I think they are "back door" units. Nobody pays the silly full price.
Also they are called mastech, digimess, grundig, and other names. Same thing. Different suppliers/countries. There are linear and switch mode ones. Different outputs in voltage and current.
Burgerman wrote:All batteries are normal!![]()
You mean lead!
Burgerman wrote:Whats an XLR charger?
I have many chargers with an XLR connector including PL8s. Shirleys power supply/charger. And a lithium charger designed to be used with a BMS with an XLR connector.
Do you mean a 2 wire, 24V powerchair lead charger? Definitely not!
Unless you also fitted a decent high balance current BMS. Which will be a problem either straight away or in a few weeks/months when it fails, or causes charge or operational issues. So if you do that you are headded for trouble!
steves1977uk wrote:Let's see if Terry cogs on why we avoid the GT Series. The price is the clue!
daunjan wrote:Hey Terry how you score the pl8 thought they were still on backorder?
steves1977uk wrote:The PL8 balance connector is the JST-PA series, 2mm pitch I think. This was posted a while back on here somewhere.
steves1977uk wrote:Here Terry... http://www.jst-mfg.com/product/detail_e.php?series=189 Seems my memory was correct.
Users browsing this forum: acid_coke, Kande_ian and 75 guests
