hank wrote:Only one i could find John
thats from our stand at a show this year!
steves1977uk wrote:Sure rover, it's a company based in Kings Lynn called Smart-Wheelchairs... https://www.smart-wheelchairs.co.uk/
Melissa (My PA) should be hearing from them next week to see if they can order it in. If they can't get it, would you be able to help?
Swan T.W. wrote:Are extra modules needed for this or just programming that is needed?
https://www.smart-wheelchairs.co.uk/wp- ... ngActuator Keypad
The Actuator Keypad allows to control the seating positions of a powered wheelchair with an R-net control system.
The keypad allows to control the actuator’s axes (lifts) 1 to 5 on an R-net system.
The keypad is available in two versions: with buttons or with paddles.
There are two different versions of keypads available for CJSM1 or CJSM2 joysticks.
Simple connection: via a 3.5 mm stereo jack into the mode socket of the joystick.
will be very interested to know what you think steve. As soon as the WCS sort out my next cheque I will be looking very closely myself. Its a choice of 3. Since for rear drive there is just 3 contenders as far as I can see that are worth looking at.
Rear drive magic mobility but cost and size make them a bit rubbish in a van or indoors. And no sensible deal. Too many $$$ Starts at 10k plus all the options... https://allterrainwheelchairs.co.uk/pro ... 9441984601
Or another salsa plus a few minor mods/adjustments like last time, viewtopic.php?f=2&t=7455&start=600#p122818
Or one of these Dietz chairs. With similar options and minor changes. ALL done, around 7k inc wheels etc. But involves discounts, and a bit of work.
Again, all depends on details The details and what can be done, because of them really matters. And access to parts at a sensible price does too.
Not 100% sure what to get yet. Need more info than is on the deitz site.
rover220 wrote:Swan T.W. wrote:Are extra modules needed for this or just programming that is needed?
No more modules required. Most chairs are pre 0rogrammed but there are some that will require a setting change.
rover220 wrote:We have just taken them on. Very nicely built and sensible pricing. Both cheaper than sunrise, better built and much better support and backup.
Swan T.W. wrote:rover220 wrote:We have just taken them on. Very nicely built and sensible pricing. Both cheaper than sunrise, better built and much better support and backup.
Do you know who makes their 12 amp charger and is it dual voltage?
rover220 wrote:Swan T.W. wrote:rover220 wrote:We have just taken them on. Very nicely built and sensible pricing. Both cheaper than sunrise, better built and much better support and backup.
Am picking one up tomorrow so will let you know.
Burgerman wrote:No idea. But all mobility chargers are junk so it doesent much matter! I suspect it will work on 120V as well. Most stuff we have here in the EU does.
rover220 wrote:http://www.ivra-electronics.nl/EN/P5/Products-Ivra-Electronics/c-Go-24V-Battery-Charger/c-Go-Battery-Charger-24V-6A-12A
Burgerman wrote:I downloaded the technical PDF. Its as useless as a chocolate fireguard.
There is NO tech info on those pdf files! Just some dumbed down marketing garbage.
Can you tell me EXACTLY what the charge algo is? CV voltage, termination based on current or time or hopefully both, and float voltage etc?
E.G. TECH CHARGE INFO:
For Gel, 14.10V CV at room temp, and terminates at 1/750thC or 12H CV limit whichever is first, then 13.45V float.
For AGM 14.50V CV terminating at 1000thC or 8 hors whatever occurs first, and 13.5 float.
Thanks!
Users browsing this forum: slomobile and 268 guests
