Dietz-Power wheelchairs
Re: Dietz-Power wheelchairs
Postby Burgerman » 05 Sep 2020, 19:29
This shows the same thing.
The number of Ah you think you got depends on discharge rate, very very heavily and on the internal battery resistance and on the battery peukert level.
So small battery scooter = disaster!
Postby Swan T.W. » 05 Sep 2020, 19:30
There is NO tech info on those pdf files! Just some dumbed down marketing garbage.
Can you tell me EXACTLY what the charge algo is? CV voltage, termination based on current or time or hopefully both, and float voltage etc?
E.G. TECH CHARGE INFO:
For Gel, 14.10V CV at room temp, and terminates at 1/750thC or 12H CV limit whichever is first, then 13.45V float.
For AGM 14.50V CV terminating at 1000thC or 8 hors whatever occurs first, and 13.5 float.
Thanks!
I
I emailed them... Lets see what they say. I am frustrated by the fact that no charger manufacturer seems able to give any sensible info. And its impossible to know if a charger is any use without it.
I emailed them on Friday, no response as of yet. .
Swan T.W.
Postby Burgerman » 07 Sep 2020, 13:55
I now have the data...
See attached PDF.
They do two sets of charge algos...
One for gel, on which they carge CV at 28.8V (too high for gel) and stop charging (terminateCV) too soon by far at 1A, and then go to float at a correct 27.2V as long as you dont leave that connected for more than a couple of days. Too high for stotage float.
Every 2nd charge they do a strange overvolt thing for 1 hour. Thats a bad idea on gel too. So they are as bad as every typical mobility charger.
And they have a different algo (determined when purchased presumably) for AGM where they use 29.4V which again is too high for some but OK for Optima or pure lead batts. But again they stop charging too early, and they do that every other charge thing where they overvolt the battery. It wont do any good but wont hurt AGMs much. Better to charge for loger in the frst place.
So. Will it work? Yes. Anything works...
Is it ideal? Far from it esp on gel batteries. Will cost you around 30% lifespan. I wouldnt use this on gel.
AGM? It does what all mobility chargers do. It over volts, and cuts off CV at around 2 hours... Relying on float to top up the battery. It will. But it will take forever.
C-go 24V charge curves v6.pdf
(358.67 KiB) Downloaded 306 times
Postby rover220 » 08 Sep 2020, 17:26
I have a rwd in at the minute should anyone want any specific measurements.
Postby Burgerman » 08 Sep 2020, 22:27
Caster centre to centre of the barrel might be interesting.
Postby rover220 » 09 Sep 2020, 05:58
500mm barrel centres.
Postby Burgerman » 09 Sep 2020, 10:50
Thanks.
500 is 19.7 inches for the inflicted. Thats enough.
Postby hank » 09 Sep 2020, 12:34
Burgerman wrote:Thanks.
What's measurements on your Salsa to compare John ;)
Postby Burgerman » 09 Sep 2020, 12:40
F55 20.5
Salsa 19.0
Dietz 19.7
All to centre of castor pivot. Inches obviously... Because thats what my carer gave me! The dietz isnt as good as the olde F55 here, but better tahn the salsa. And that works great with 9 inch tyres and a bit tight with 10 but thats how mine is. So the Dietz should be the 3rd candidate that allows a centre plate and moving the seat back to get proper control/CG and stop it being an oil tanker.
Postby hank » 09 Sep 2020, 13:01
Thanks all good for centre footplates :thumbup:
Postby CPguy » 15 Sep 2020, 13:29
What is a "centre of barrel" in this context please? I only know the term barrel from wine and weapons.
My rides:
2 Progeo YOGA (for traveling)
CPguy
Postby hank » 15 Sep 2020, 13:48
Between the front Centres of the shaft castor forks locknuts located in the frame
Postby CPguy » 15 Sep 2020, 15:21
Ok, so its measuring across, caster to caster. Thank you!
My rides:
CPguy
Postby steves1977uk » 27 Oct 2020, 18:32
Having seeing and a small test drive of the RWD Dietz chair, I must say I was very impressed with it! :thumbup:
Also rover220 was a super helpful guy. :) Looking forward to buying it and getting it set up properly.
Postby Burgerman » 27 Oct 2020, 18:37
Did it have a centre power footplate by any chance?
If I were to buy one, how would I get parts easily at a sensible price?
Say -20% and no VAT?
Anyone using VR2 or pre R-Net PG Drives controllers on ANY chair, can get OEM/Manufacturing (Covrers A, B and C access levels) on the Dietz download page here: https://dietz-power.com/downloads-dealer-login/
Anyone wanting the OEM version of the R-Net generic software, for all R-Net chairs, can get it on the Dietz download page too https://dietz-power.com/downloads-dealer-login/
Unlike all the rest that pretend it doesent exist, or refuse to supply, you can download it straight from their website. An enlightened manufacturer. And the only one I found ever...
Postby steves1977uk » 27 Oct 2020, 18:57
No it had the adjustable manual swing-aways footplates, which were needed for my foot control. A centre footplate wouldn't work for me since I need them separate and strong for to be able to push myself up with help.
Not sure about spare parts yet as I didn't get that far!
Postby rover220 » 27 Oct 2020, 20:13
Glad you were impressed with it Steve, they are good kit. Steve's chair will need some very custom mods footrest wise but nothing that can't be achieved.
Postby Burgerman » 27 Oct 2020, 20:31
Does anyone know the caster width on the Q700R or/and Q500R still? :wave:
Postby rover220 » 27 Oct 2020, 20:44
Burgerman wrote:Does anyone know the caster width on the Q700R or/and Q500R still? :wave:
afraid not.
Postby Burgerman » 27 Oct 2020, 20:58
Bugger!
Someone must have one... I may have to call sunrise :|
Postby Arima » 27 Oct 2020, 21:37
I'll ask the dme for an engineering drawing for the q500r next time we speak.
Thxs
Arima
Postby Burgerman » 27 Oct 2020, 22:01
The 700r is a better bet.
Postby Colin uk » 31 Oct 2020, 01:32
I've not come across the Dietz line before. Quite interesting.
I'm actually quite interested by this one at 53cm / 20.8" wide & the single rear wheel makes me wonder what that would be like to live with. The rear casters at the corners usually limits these in practice. Although this adds length, it also looks like you could back up quite close to a wall once that caster has spun.
It's not perfect, but the narrow frame, less rear swing restriction and avoiding the seat being to far forward from the rear drives is ticking some big boxes on initial look.
Colin uk
Postby rover220 » 31 Oct 2020, 07:16
The slimline chairs are proving very popular, especially the 5 wheel model.
Postby DIETZPower » 06 Jan 2021, 17:10
Hi All,
If you need any further details on the DIETZ range of powerchairs please let me know what you need and I will see if I have something I can get hold of for you.
DIETZPower
Postby duke1 » 06 Jan 2021, 17:56
DIETZPower wrote:Hi All,
hi i was looking for a showroom or dealers i could take my tina to see and try a dietz chair but found none in southeast england and its hard to commit to buying an unseen product so we have had to look elsewhere,did i miss a dealers here?cheers
duke1
Postby steves1977uk » 06 Jan 2021, 23:39
Welcome aboard! :thumbup: Will be getting my new Dietz powerchair soon hopefully. :)
Postby Burgerman » 10 Jan 2021, 11:58
Any news yet? Looking forward to decent pics and opinions on it. Did you go rear drive?
Postby steves1977uk » 10 Jan 2021, 12:50
Yes BM, I went for RWD and have paid a deposit to rover. So should be getting it soon! :)
Postby rover220 » 10 Jan 2021, 12:59
steves1977uk wrote:Yes BM, I went for RWD and have paid a deposit to rover. So should be getting it soon! :)
Well you've not paid it to me exactly.
Users browsing this forum: faico_26, jehan, LROBBINS, shirley_hkg, tettralytic and 583 guests
