darky wrote:Thank you Woody for the fast reply!
Unfortunately i don't have the possibility to get the 1N4148, can something dangerous happen if i don't use it?
To be sure, which is the latest wiring diagram?
Anyway in my third question i meant exactly the bigger molex connector of 14 PIN, because i saw a video where he has connected together the 5-7 pins, so i don't have to do it if i can turn on the scooter normally, right?
Burgerman wrote:Blutac. Its a great silencer.
darky wrote:Yeah to cut the beeper was the first i tought, but in this way i would have lost the diagnostic/warning part of it.
About the rest, i did all the wiring but something doesn't want to work... it seems all conneted fine but it stay on COMMS INACTIVE.
I also did the looptest that went fine
is it right in this order? http://puu.sh/GG3kw/071591bb3c.jpg
C = TX+RX (i think this is the only sure one)
but of the other two input, is the 1 or 2 the negative one?
i'm using a 54k resistor it's ok? (if i remove it, when i connect the usb converter windows get an error driver)
woodygb wrote:Darky ...Could you please alter your profile to give in an approx location.
Burgerman wrote:Can I get anchovies on mine?
Users browsing this forum: Juggler258 and 425 guests
