USEFUL PARTS & ACCESSORIES * * *
Re: USEFUL PARTS & ACCESSORIES * * *
Postby ex-Gooserider » 24 Sep 2020, 07:49
Please express in form of top of the fender and chord length , instead of the base line and angle .
Also , I recommend it to cover the entire tyre width.
Working on a modified drawing, should have it soon...
I emphatically do NOT want the fender to cover the entire tire width! I am often needing to get into tight spaces or nerf things out of the way with the chair, and this means scraping and rubbing - If the contact point is the tire, I am unlikely to damage the tire or the thing I'm contacting... If the contact is the fender it will be damaged.... Therefore I want the fender to only cover as much of the tire as is necessary to keep the crap (or at least most of it) off the me and the chair....
Postby ex-Gooserider » 25 Sep 2020, 03:54
fender-sketch-2.pdf
Revised fender sketch drawing
(72.11 KiB) Downloaded 338 times
New drawing, w/ chord lengths and a couple of other minor tweaks....
Would prefer aluminum or stainless over mild steel unless that makes a big difference in the price.
Postby Burgerman » 25 Sep 2020, 06:47
Aluminium will not be strong enough. Unless 5mm thick. Esp edges and mounting. Put your hand on it and bend the mounting...
Postby ex-Gooserider » 25 Sep 2020, 21:06
Burgerman wrote:Aluminium will not be strong enough. Unless 5mm thick. Esp edges and mounting. Put your hand on it and bend the mounting...
Can hardly be worse than the stock fender - plastic, ~2.4mm / 0.96" thick... Looks like polypropelene.
Worth remembering this fender isn't really intended as a load bearing thing, just a crap stopper...
Postby snaker » 28 Sep 2020, 02:04
I found this QC 3.0 board, $2.5. It looks physically good, best if compared to other QC 3.0 boars. I am using it to feed my camera in place of my powerbank, it works better than the board in my powerbank. Making cable is fairly easy, just soldering 2 wire and heatshrink.
Input: 8-30V
Output: auto 5/9/12/20V
https://shopee.vn/product/35743738/7717504511
Postby shirley_hkg » 19 Oct 2020, 11:45
These angle studs will help DIY boxes easy and look nice .
Postby shirley_hkg » 19 Oct 2020, 11:48
Has slots for M3 nuts .
Postby shirley_hkg » 30 Oct 2020, 01:05
Nice switch box .
Postby ex-Gooserider » 03 Nov 2020, 03:58
Interesting,
Do they give dimensions for the switch holes? (is there a choice, or possibly a blank for 'drill your own'?)
Do they offer more switch types than the push-buttons or mushrooms shown? (i.e. all the different variations of toggle switches....)
Postby Burgerman » 03 Nov 2020, 04:06
Those switches are all 16mm diameter threads so holes will be 16mm + clearance.
Postby shirley_hkg » 03 Nov 2020, 14:34
Yes. They offer different hole sizes ; 12,16,19,22,25 ....., and have (blank) one for drill yourself too.
2 box sizes : 45mm / 65mm , with or without mounting holes.
Postby shirley_hkg » 06 Nov 2020, 16:23
Got my set. Switch looks gorgeous. :thumbup:
Less than £3 for what's in the pic .
Postby shirley_hkg » 06 Feb 2022, 09:41
Compact switches.
£2 … £3
Self lite optional . cheers
Postby Frank » 04 Mar 2022, 17:13
Can someone please give me a link where to buy these boxes without mounting holes? thanks
Frank
Postby Frank » 05 Mar 2022, 08:29
Frank
Postby shirley_hkg » 22 May 2022, 05:12
Now you have more choices.
Postby steves1977uk » 22 May 2022, 23:06
Those HY2+9P look ideal for our packs, whats the current rating on those please Shirley?
Postby shirley_hkg » 23 May 2022, 01:18
Postby fishinjunky » 25 May 2022, 14:05
what does the shell for these look like?
Postby shirley_hkg » 25 May 2022, 14:28
No shell.
Postby shirley_hkg » 25 May 2022, 14:32
Bracket for Anderson SB50.
Postby shirley_hkg » 30 Jun 2022, 00:20
Nice Dsub connectors .
9 pins for balance leads . 4 large pins for charge main cables , double wires .
Postby shirley_hkg » 30 Jul 2022, 14:07
LROBBINS wrote:IF I can get motors with both angle sensor for sinusoidal commutation & brake - but the brake has to have a manual release if the gearcase doesn't have a clutch. Otherwise,
Good for DIY , dirt cheap . £4 each .
Postby slomobile » 30 Jul 2022, 22:17
I'd like 4 of those brakes. Any idea what the mounting bolt circle dimensions are? 2 of the shaft adapters need to mate a .31" D shaft for Quantum 4 front motors, and 2 need a 1/2" hex hole, but I can drill and manually file the hex.
slomobile
Postby shirley_hkg » 31 Jul 2022, 03:39
Disclaimer : All information we have are just photos, and nothing but the photos. :lol:
Price doesn't include shipping. cheers
More photos :dance
Postby shirley_hkg » 31 Jul 2022, 03:43
More photos :dance
Postby shirley_hkg » 31 Jul 2022, 04:23
Here is another one from CHAINTAIL Taiwan . :dance
Postby shirley_hkg » 31 Jul 2022, 04:26
More .
:clap
I think these are surplus / new old stocks . cheers
Postby shirley_hkg » 20 Jan 2023, 06:51
Postby expresso » 20 Jan 2023, 22:34
shirley_hkg wrote:cheers
where can i get these ? or can you get them for me ?
these look to be strong heavy duty enough - small package -
any links to the item so i can search here also
like this one - if small pins can handle a 22 awg at least for balance - it can be a future option - compact
Users browsing this forum: Bing [Bot], emilevirus, jefferso, slomobile and 383 guests
