Wllunn wrote:How do I purchase the bm3?
I’m looking to use it for getting around my yard
Burgerman wrote:Tom makes a loose clone of the chair. But he uses stock powerchair components. You wont find 45V lithium, 15A 50V roboteq controller, 16mph, etc.
Burgerman wrote:Well one of the most popular manufacturers certainly doesent! And this is why DEALER LEVEL programming is useless. Well one of the reasons!
Look at this STOCK programming with WALLS set up here! On my new Sunrise Q700R.
No way to make the damned thing steer with all these wallS set up! I need to set at least 4 of those to 100 in "speeds" to make it steer. And others to higher than it will allow in other settings. And deceleration to less than it allows. DEALER = Useless for this chair.
One before. With all the restrictions.
One showing all the ones now set properly!
Burgerman wrote:You MIGHT need to change the character of the software to permobil from the top menu. CONTROLLER>PERSONALITY to permobil. If it will.
Burgerman wrote:It enables/removes different menu items that may only be used on say permobil or sunrise chairs.
But only if you have a preset from the chair with these things. For e.g. on the sunrise software there are special sunrise advanced seating settings and some reserver for future use stuff.
Burgerman wrote:After playing with it I edited the above. I need a permobil to test for sure. The GENERIC version has no switches or sunrise seating options. So the CRTL+5 cannot be edited. Or maybe not work... So you need to tell the controller its SUNRISE if its a generic version. Or a permobil version. And then these thins should be available? Need more chairs to test.
I have assignable buttons? I think. Certainly the switch it ones are easy to config. (the CTRL+5 for e.g.)
Not sure about joystick will look later. Although I already junked the HAZARD lights and that button now takes me to programming on a short press. And something else (I forget) on a long press... Did that on the salsa 3 years back.
Burgerman wrote:Isnt that what one of the changes when you choose the sunrise controller personality? So that the software then has the same capability as it does with a sunrise chair?
Burgerman wrote:Thats strange.
Does it add the switch-it stuff?
Users browsing this forum: Seafighter, shirley_hkg and 322 guests
