dc5dd wrote:Woody, you better give me that diode anyway Newark has flat rate shipping and I minus will get that while I'm at it. Danny
Burgerman wrote:Any old diode will work, and any old low drop type is even better?
tabbott916 wrote:Perfect! let the fun begin, I will post how it goes.
If Load Compensation is set too high, the chair
- Drives very rough
- Is hard to steer or control, vibrates or surges
woodygb wrote:There is no need for a 24v connection... any power requirements ( 5v ) are met by the TTL-USB adaptor.
The diode is not required ,I simply added one as a "safety" feature.
Connections to the Molex will be just GND ( pin 1 ) and the multifunction pin (pin 4 ) NO 24V +
Should you wish one I can supply you with one.
, I decided to re-wire the Rhino2 controller without the invacare card.Return to Everything Powerchair
Users browsing this forum: No registered users and 305 guests
