DWIZ-ADAPT
Re: DWIZ-ADAPT
Postby woodygb » 12 Oct 2020, 17:36
NOTE:- You will need the hacked Wizard software.
Re: DWIZ-ADAPT
Postby dc5dd » 12 Oct 2020, 18:53
Yup, I noticed a doide in your 7Gluk desgin?
dc5dd
Re: DWIZ-ADAPT
Postby woodygb » 12 Oct 2020, 22:59
The diode is probably not required , it was simply an addition by me as a "safety" feature , so this diode is most likely not needed.
Re: DWIZ-ADAPT
Postby dc5dd » 30 Oct 2020, 21:29
Woody, you better give me that diode anyway Newark has flat rate shipping and I minus will get that while I'm at it. Danny
dc5dd
Re: DWIZ-ADAPT
Postby Burgerman » 30 Oct 2020, 21:50
Any old diode will work, and any old low drop type is even better?
Re: DWIZ-ADAPT
Postby woodygb » 31 Oct 2020, 00:01
dc5dd wrote:Woody, you better give me that diode anyway Newark has flat rate shipping and I minus will get that while I'm at it. Danny
I used a 1N5711 SMALL SIGNAL SCHOTTKY DIODE ... because I had some...
Re: DWIZ-ADAPT
Postby dc5dd » 31 Oct 2020, 00:40
Burgerman wrote:Any old diode will work, and any old low drop type is even better?
Oh the "any old diode" routine :thumbup:
dc5dd
Re: DWIZ-ADAPT
Postby Burgerman » 31 Oct 2020, 03:17
Say these 99p delivered. https://www.ebay.co.uk/itm/1N4148-Signa ... Sw4-td9obH
But a schottky high frequency small signal type diode would be better still. https://www.ebay.co.uk/itm/1N5711-Small ... SwT6ld9odF
1.69 delivered...
Re: DWIZ-ADAPT
Postby 7Gluk » 18 Nov 2020, 21:57
I changed the circuit of the adapter to fit the newVSI remote. I have two WC with different remote, and it is more convenient to have a universal adapter.
1. For the DA50-A41 remote, you need to open J1 and short J2.
2. For the newVSI remote, you need to open J2 and short J1.
J1 can be replaced with a diode D1. But I can't check now whether the diode will affect the work with the DA50-A41 remote (that WC remained in the country).
Woody's resistors can be used too. But if the R1 is different from mine, the R10 may need to be adjusted.
And as I already say: ATTENTION: do everything at your own peril and risk!
7Gluk
Re: DWIZ-ADAPT
Postby deswong » 11 Jan 2021, 09:20
tabbott916 wrote:Perfect! let the fun begin :) , I will post how it goes.
How did it go?
I started gathering parts for the Anubis801 version but if the 7Gluk one works just as well I think the 7Gluk is easier to build.
deswong
Re: DWIZ-ADAPT
Postby pdumitru » 22 Jan 2021, 15:35
Hello!
i got a Mercury M36 mobility scooter that no longer works. I found that the controller is defective and I bought one from ebay which unfortunately comes from diffrent model of scooter and it needs to be reprogrammed.
I would like to try to save the settings from the faulty controller (if is possible) and load them in the good one.
I just need wizard5 and some advice .
Thanks!!!
pdumitru
Re: DWIZ-ADAPT
Postby woodygb » 22 Jan 2021, 15:42
Which controller ...Rhino or Rhino 2?
Re: DWIZ-ADAPT
Postby pdumitru » 22 Jan 2021, 16:42
Rhino DS72K01
pdumitru
Re: DWIZ-ADAPT
Postby woodygb » 22 Jan 2021, 18:09
You have a P.M.
Re: DWIZ-ADAPT
Postby pdumitru » 22 Jan 2021, 18:53
Thank you very much!
pdumitru
Re: DWIZ-ADAPT
Postby pdumitru » 24 Jan 2021, 16:52
I have tried to connect the damaged controller to my computer with no success.
I can only connect the good one, but i have no idea how to do the right settings.The scooter is shaking at low speed, especially on reverse direction.Can you help me to find the right settings for Mercury M36, please?
pdumitru
Re: DWIZ-ADAPT
Postby woodygb » 24 Jan 2021, 17:02
It could be the motor load compensation setting.
Load Compensation Value: Load Compensation (mOhm)
If Load Compensation is set too high, the chair
- Drives very rough
- Is hard to steer or control, vibrates or surges
Try taking the existing number lower and use small increments .... reduce by 5 mOhm each time ...test and repeat if needed.
IF IT GETS WORSE, STOP AND REVERT BACK TO THE ORIGINAL SETTING.
Re: DWIZ-ADAPT
Postby woodygb » 24 Jan 2021, 17:19
https://manualzz.com/doc/23099492/rhino ... ion-manual
Page 56 - 57 gives you the procedure for setting the Load Compensation value.
Re: DWIZ-ADAPT
Postby pdumitru » 28 Jan 2021, 20:11
After several attempts to find the correct load compensation value I decided to tried to fix the faulty controller. After several measurements I finally found a tantalum capacitor in short circuit. after replacing the capacitor I was able to read the original settings and load them in the good controller.Like you said the load compensation was to higt 140 and the original settings is 30. Thank you for your support!
pdumitru
Re: DWIZ-ADAPT
Postby woodygb » 28 Jan 2021, 20:34
You can probably tweak ( increase ) that 30 setting a little.
Re: DWIZ-ADAPT
Postby pdumitru » 28 Jan 2021, 20:58
I tried 50 and it's drive ok. Do you think is better to leave it 50. is not gonna damage the electric motor ?
pdumitru
Re: DWIZ-ADAPT
Postby woodygb » 28 Jan 2021, 23:08
50 should be fine and will not damage the motor.
Re: DWIZ-ADAPT
Postby FelipeOliveira » 03 Feb 2021, 04:04
woodygb wrote:There is no need for a 24v connection... any power requirements ( 5v ) are met by the TTL-USB adaptor.
The diode is not required ,I simply added one as a "safety" feature.
Connections to the Molex will be just GND ( pin 1 ) and the multifunction pin (pin 4 ) NO 24V +
Should you wish one I can supply you with one.
OLA Woody , tudo bem por ai ??
tenho interesse ,
Se puder me enviar mais informações !!
Saudades de suas orientações , independente disso é sempre bom fazer contato com você !!!!
FelipeOliveira
Re: DWIZ-ADAPT
Postby woodygb » 03 Feb 2021, 10:46
Hi Felipe.
What do you need to know?
Re: DWIZ-ADAPT
Postby titix24 » 02 Mar 2021, 17:54
Hello, I am new to the site and therefore sorry for my English (thanks to google translate !).
I bought an invacare comet (Dymamic Rhino 2 120A controller) whose control card just broke.
Since the repairman asked me 1500 euros for this elctronic Board :cussing , I decided to re-wire the Rhino2 controller without the invacare card.
I managed to rewire for the scooter to start and move but I would like to try to rewire everything and I would have to access the complete programming of the Rhino DS120A controller. For me, it is out of the question that I buy 600 euros a programmer that will not allow to access all the parameters.
Do you have a solution from the dynamic Wizard software?
I have read a good part of the forum topics, where we are talking about a special version of the PC Wizard 5 software.
Merci d'avance.
Titix
titix24
Re: DWIZ-ADAPT
Postby Yennek » 06 Mar 2021, 03:34
Before I build the adapter, does anyone know if the Wizard software will read/write to the Invacare MK6? I see it on the list in the "about" window, but didn't find any posts where anyone actually mentioned using it.
Thanks!
Yennek
Re: DWIZ-ADAPT
Postby titix24 » 06 Mar 2021, 10:45
Hello,
I have a little trouble understanding the connection between the computer's USB and the XLR (or 4-pin molex) connector on the controllers.
Do we connect the serial USB adapter directly to the controller (rhino2), or do we need an intermediate adapter (gluk's assembly)?
Titix24
titix24
Re: DWIZ-ADAPT
Postby woodygb » 06 Mar 2021, 11:28
The Rhino2 requires the adapter.
Re: DWIZ-ADAPT
Postby woodygb » 06 Mar 2021, 11:39
Re: DWIZ-ADAPT
Postby titix24 » 06 Mar 2021, 14:13
Ok thanks a lot.
It is clear for me now : i have to read carefuly previous posts !
titix24
titix24
Users browsing this forum: emilevirus, jefferso, martin007 and 518 guests
