wes4dbt wrote:Ok, you convinced me, I should get a proper charger for gel batteries.
What a major pain in the arse.
I thought, I'll just Google "24v gel battery charge" or "24v duel mode battery charger". I spent hours basically looking at the same thing I got now. Found a couple "duel mode" but could never find any specs on the max voltage or float voltage in each mode.
At Battery-charger.com they say they can set the voltages to what you want but they don't actually sell directly, you have to find a distributor. I called them but got a recording. I don't trust that if I call some company I find online and ask if they would set the voltages that they actually would, I wouldn't know.
Victron IP 67 [12 amp] or IP 65 [8 amp] Smart chargers would do what you need. They can be set for Gel or AGM.
I'm not willing the rewire my battery charging system, I'm sticking with the XLR plug. So, I guess for now I'll just wait and see what happens with these new batteries. I've been thinking about getting a chair with 24's, this might be the push I need to spend the money.
I do appreciate all the information that you provided. Thanks
wes4dbt wrote:Victron IP 67 [12 amp] or IP 65 [8 amp] Smart chargers would do what you need. They can be set for Gel or AGM.
I went to the Victron website and none of their IP 67 or IP65 models had a gel mode. They all charged to 28.8. Maybe they don't make the model your talking about anymore. Or did I go to the wrong site?
wes4dbt wrote:Tried to check out the "shirley power supply charger" but didn't find anything.
Dont be scared you can order one ready to go! With or without the fancy case.
I looked at the chairs specification. It uses a PG Drives controller. Its max capability is 70A. per side.
Anyway reading the controller manual it says it can handle up to a 12a charger. Is it safe to assume that the rest of the chairs wiring harness can handle a 12a charger? Why does the chair come with a 5a charger????
The reason I was checking this out was a quality charger like the PL8 lowest current is 10a.
I've noticed some of you guys talking about the PL8. Are there adapters available to take the output from the PL8 and use a XLR connector. I know this is not ideal but because of lack of hand function and difficulty in bending down, it would make my life easier if I could use the easily accessible XLR connection.
wes4dbt wrote:Obviously you've mistaken me for someone with wiring/soldering experience. Don't own a soldering iron, never soldered. But hell I'll try just about anything.
Let's see how well I understood what you said.
Wire, https://www.ebay.com/itm/2-CORE-ROUND-T ... w&LH_BIN=1
4mm connector https://www.ebay.com/itm/Lot-20Pc-4mm-G ... Sw-0RbHexM
XLR connector https://www.ebay.com/itm/1Pcs-XLR-Male- ... SwuQpgUcV0
Also, is this the correct PL8 and is this the best site to buy it from. https://www.progressiverc.com/products/ ... gJ1PPD_BwE
Didn't you read the part of my previous post that said "I'm a plug and play kind of guy" lol
so i ending getting the better one anyway - also i did a better job with the better iron - etc, at least for me it was worth it
wes4dbt wrote:I just noticed the power plug for the PL8, will I have to make a cable for connecting to the 120 outlet?
expresso wrote:wes4dbt wrote:I just noticed the power plug for the PL8, will I have to make a cable for connecting to the 120 outlet?
No the PL8 gets plugged in the PSU - then the PSU plugs in your outlet -
Users browsing this forum: shirley_hkg and 101 guests
