Roadrunner wrote:Still can't access assignable buttons. They doesn't show in the programmer.
Anyone know if it has to do with the dongle/firmware in the power module or perhaps the joystick?
Burgerman wrote:. Rover reports that some wont allow any programming from a standard R-Net programmer.
Burgerman wrote:But OEM level permobil software is not available. So what else would you use?
Roadrunner wrote:Thanks for your time and help.
This is what I did today.
Opened a Sunrise config file (Salsa-M2) with the Sunrise oem programmer.
In view - dropdown menu - show checkboxes - marked what I wanted to use (assign buttons and softkeys) and did the configuration i wanted.
Saved the file as a subset file (rnss).
Opened it in the generic oem programmer and wrote to controller.
Now there´s the extra settings on the jsm2 that I choose!
A little workaround but it works
Roadrunner wrote:Yes !
Roadrunner wrote:Yes this was what i did.
In the sunrise oem - opened the Salsa.
View - show checkboxes.
Choose everything in the far left (from file description to IDevice2).
Then deselected everything but the controls.
Then in controls/assign buttons - i choose what i wanted to - and in softkeys i choose to enable softkeys and the function of the softkeys (first and second function).
Then i saved as a subset file - closed sunrise oem - opened with generic oem - opened the subset file and wrote to controller.
Burgerman wrote:Are we talking permobil? Probably different firmware. They seem to love to have different versions and non compatible ones.
Burgerman wrote:Ah, danish TA?
Never saw one even! Other than pictures. Should be possible though I would expect? Unless they do "funny" permobil like stuff and mess with firmware that only allows permobil OEM versions that we and their own techs cannot access.
rover220 wrote:Got the 4 soft keys to work but what I really want is true assignable buttons sorting.
Users browsing this forum: No registered users and 234 guests
