Burgerman wrote:Only ONE wire solders to the inside of the PL8.
Burgerman wrote:Thats a schematic. That would also work. What do you think that servo lead is for?
PLUG that into the same 3 pin connector OUTSIDE!
Run the wire to the INSIDE and solder the ends to the black negative and the signal wire? Green.
LOOK CAREFULLY!!!
I have only said this about 10 times so far!
steves1977uk wrote:That's if you don't want the servo lead connected expresso, completely internal. With the servo lead sticking out the back, you can use the FUIM3 or the BT.
Burgerman wrote:And it only took 67 posts and 22 pictures and 4 days!
thats actually a short time - considering - i left the PL8 open so i can get this done
Now you know what to connect to what, you can do a simple wiring system, without wires all soldered to each other etc. So its easy to bung inside. Simplicate it.
Burgerman wrote:As I said. Painting by numbers doesent work.
You just need to know what those 2 boards do. And what their connection mean and thats written on them!
Then YOU can wire it in the easiest, neatest way you wish. What matters is whats going on electrically. Not pictures or other stuff. A schematic is just that a circuit diagram. HOW you connect it all physically is your business.
At the end of the day its super simple, 4 wires, a string. PL8 one wire soldered. > UBEC output to BT Module > BT module to servo wire. And not even the red... And I was telling you this endlessely but you wasnt reading it and wanting pictures...
Burgerman wrote:PL8 POWER (+ ONLY) to UBEC input.
UBEC output to BT plus (+) and minus (-) connections.
Servo wire to BT minus (-), and signal connection. red (+) not connected.
THAT IS IT!!!
Thats ALL you needed to know.
Burgerman wrote:73 posts, woody is in a mental institution, and I am frustrated.
Its actually easier than doing it externally...
Users browsing this forum: Burgerman, daveonwheels, Jay_x, Qvickster and 46 guests
