DWIZ-ADAPT
Re: DWIZ-ADAPT
Postby woodygb » 22 Aug 2021, 09:30
Question ... You have got the controller turned ON ?
Re: DWIZ-ADAPT
Postby Kaschperlpropper » 22 Aug 2021, 10:24
i tried ignition on and ignition off. both times I did not get a connection to the control unit.
Kaschperlpropper
Re: DWIZ-ADAPT
Postby woodygb » 22 Aug 2021, 10:35
Ignition MUST be ON.
There is no trick or special setting used in getting the interface to work .
Has your TTL-USB adaptor installed it's drivers correctly?
https://www.miklor.com/COM/UV_Drivers.php
Re: DWIZ-ADAPT
Postby Kaschperlpropper » 22 Aug 2021, 11:11
yes the driver is installed correctly. first it was on COM 8 then I switched to COM 2 because I thought that the software might not work with COM 8. I also measure a signal whenever the software checks the various ports with the oscillator between DATA and GND. The picture of the control unit that you sent has a different connector arrangement than that of the control unit from me. Can this be the reason?
Kaschperlpropper
Re: DWIZ-ADAPT
Postby woodygb » 22 Aug 2021, 12:49
Kaschperlpropper wrote: The picture of the control unit that you sent has a different connector arrangement than that of the control unit from me. Can this be the reason?
No ...
Sorry about the incorrect controller ...here is yours.
Re: DWIZ-ADAPT
Postby Kaschperlpropper » 22 Aug 2021, 15:09
maybe someone could give me the ohmic values when I measure rows 1 to 7 ohmic on the circuit board from above.
Thank you for your help
Kaschperlpropper
Re: DWIZ-ADAPT
Postby woodygb » 22 Aug 2021, 15:21
I haven't currently got one made , so cannot supply you with any Ohmic values...give me a couple of days and I will build one
Re: DWIZ-ADAPT
Postby FrenchGuy » 22 Aug 2021, 18:53
Hello again,
If it's can help for me after changing the USB/RS232 adapter it's working find.
However I have made changing in the controller (increasing the speed of course) but the difference is not much.
May I send you the file with the new setting for some advice?
Thank you
FrenchGuy
Re: DWIZ-ADAPT
Postby woodygb » 22 Aug 2021, 19:20
FrenchGuy wrote:Hello again,
Thank you
Yes...feel free to do so.
Re: DWIZ-ADAPT
Postby FrenchGuy » 22 Aug 2021, 20:49
good evening,
This is the file.
Regards
LeoGunnVitesse.zip
(2.71 KiB) Downloaded 466 times
FrenchGuy
Re: DWIZ-ADAPT
Postby woodygb » 22 Aug 2021, 21:52
Your program is already at it's limit as far as SPEED is concerned.
It is however possible to add a little more urgency to the acceleration, but as I have said, nothing extra to the top speed.
Re: DWIZ-ADAPT
Postby woodygb » 25 Aug 2021, 16:51
Kaschperlpropper wrote:maybe someone could give me the ohmic values when I measure rows 1 to 7 ohmic on the circuit board from above.
Here you go ... resistances are measured from track to track.
Re: DWIZ-ADAPT
Postby Daf » 25 Aug 2021, 19:30
Got the package today. Stuck at customs for a while.
Thank you. You even did the contacts and cabeling. Thank you! It should be a no brainer for me to get it working ;-)
Daf
Re: DWIZ-ADAPT
Postby woodygb » 25 Aug 2021, 20:23
:thumbup:
Re: DWIZ-ADAPT
Postby FrenchGuy » 28 Aug 2021, 13:20
woodygb wrote:Your program is already at it's limit as far as SPEED is concerned.
The Maximum Forward speed value change from 50 to 100 in Profile 2 -> no effect.
I also try to disable the Profile 2 in the Multi-function Inputs configuration with no success.
The maximum speed stay at 8km/h.
Any idea?
FrenchGuy
Re: DWIZ-ADAPT
Postby woodygb » 28 Aug 2021, 13:27
Why do you think that 8 km/hr is not it's top speed?
https://www.dynamiccontrols.com/sites/d ... ue%209.pdf
Re: DWIZ-ADAPT
Postby woodygb » 28 Aug 2021, 13:45
Any idea?
What make and model of mobility scooter do you have?
Re: DWIZ-ADAPT
Postby FrenchGuy » 28 Aug 2021, 14:07
Any idea?
I've got an Invacare Léo
FrenchGuy
Re: DWIZ-ADAPT
Postby woodygb » 28 Aug 2021, 14:28
https://www.mobilitysmart.co.uk/invacar ... 0%7C%20Leo
Maximum driving speed: 8 km/h (5 mph)
Your scooter is geared to do 8 km/hr and you CANNOT go faster.
Re: DWIZ-ADAPT
Postby FrenchGuy » 28 Aug 2021, 14:32
If it can help this is the original setup
LeoGunnDefaut.zip
Original setup
(2.74 KiB) Downloaded 434 times
FrenchGuy
Re: DWIZ-ADAPT
Postby FrenchGuy » 28 Aug 2021, 14:38
woodygb wrote:https://www.mobilitysmart.co.uk/invacare-leo-mobility-scooter.html?msclkid=5185e2247cea15a0f49d830e45334307&utm_source=bing&utm_medium=cpc&utm_campaign=Mobility%20Scooters&utm_term=invacare%20leo&utm_content=B%20%7C%20Invacare%20%7C%20Leo
Bad news so no trick available....
FrenchGuy
Re: DWIZ-ADAPT
Postby woodygb » 28 Aug 2021, 14:40
Correct.
Re: DWIZ-ADAPT
Postby Kaschperlpropper » 01 Sep 2021, 10:26
First of all, many thanks to Woodygb. everything works now. i had a short circuit. I only found it through your information on the ohmic values. i'm really happy now
now I have one more question ... there are 2 files for the Rhino 90A.
i have taken the Rhino2C90A.wpr .. what is the difference to Rhino2C90A_ACT.wpr
many thanks for your help. You're awesome
Kaschperlpropper
Re: DWIZ-ADAPT
Postby woodygb » 01 Sep 2021, 11:31
I am guessing that ACT stands for ACTuators.
Re: DWIZ-ADAPT
Postby wcd@tawebster.co.uk » 22 Sep 2021, 17:12
Hi there,
So following on from the post here https://www.wheelchairdriver.com/board/ ... =2&t=10808, I have created the homebrew circuit, added the FT232 as noted on this board. I have installed the stock Wizard 6 (not the hacked/modified one). The USB-rs232 driver is showing pretty lights when I connect, and is setup as COM4, but the Wizard is not seeing any hardware or doing anything other than annoying me. So, I presume, it's either that I need the functioning (hacked) Wizard, and if so, can anyone send me a link for it? Or my homebrew circuit is at fault. I have checked all components for functionality, and all seems well (to my amateurish knowledge that is), but this post earlier https://www.wheelchairdriver.com/board/ ... ic#p177265, shows correct ohm values across veroboard lines, but the second and third values on my board are showing as 68.7k instead of 43.2k, and 79.11k instead of 54.2k - all the others are the same. Should I worry about this :roll: . Pics of my actual board attached.
Any help would be incredibly appreciated.
https://www.dropbox.com/s/5g8j89p9qqgxz ... 8.jpg?dl=0
https://www.dropbox.com/s/b8rwfibqcke3s ... 1.jpg?dl=0
wcd@tawebster.co.uk
Re: DWIZ-ADAPT
Postby woodygb » 22 Sep 2021, 17:30
I would suggest that you might have a board build fault ... it really depends on the exact resistor values that you used.
The difference between both sets of seemingly errant ohms values is much the same @ 25 ohms ish .
It will not matter ....for testing purposes...what Wizard you use.
Re: DWIZ-ADAPT
Postby woodygb » 22 Sep 2021, 17:47
I had a quick look at the colour codes and you appear to have used exactly the same as my build pics...thus I must conclude that you have a build error
Re: DWIZ-ADAPT
Postby wcd@tawebster.co.uk » 22 Sep 2021, 18:10
Thanks Woody.
Ive checked each component multiple times, so I think I'll just knock up another veroboard tomorrow. Could be a duff component I guess. Or more likely a soldering issue...?
wcd@tawebster.co.uk
Re: DWIZ-ADAPT
Postby woodygb » 22 Sep 2021, 18:30
NOTE:- I am NOT an electronic expert... try replacing Q1.
OR ..should you wish ..post it to me and I will look at it for you.
Re: DWIZ-ADAPT
Postby wcd@tawebster.co.uk » 23 Sep 2021, 15:18
Hey Woodygb,
So I've built another circuit, with all new components, but amazingly it shows the same erroneous ohm readings as the first. Can only assume I have purchased some dodgy components, so I'd like to take you up on your offer - perhaps you would PM me your address and I'll send both boards, and a postage paid sae.
wcd@tawebster.co.uk
Users browsing this forum: emilevirus, snaker and 441 guests
