Thought of topping up cells individually , but … … IS THREE A EASIER WAY. Took the 2 alligator clips off the battery mains , and tap on a cell . Since the BMS was still in action, I was able to tune the charge volt and amp up, without worrying of overcharged the cell. It worked and all 4 were topped up in 3 hours.Burgerman wrote:I doubt you will use it but its free so why not. As long as YOU have the tech knowledge it can test single lithium cells.
It sound like a high resistance cell. It should take about 100A if its a 100Ah cell when that low. At least to pull it up high to 3.6V.
And should take 10 hours at 10A. Since its about 100% discharged. So that sounds like these cells are all going to be junk.
When charged, do a full discharge test. You might be horrified.
The cell you are doing now, do a 10A discharge test on that one alone. And you may find its only good for a fraction of what it should be. And may have very high resistance and high self discharge too.
expresso wrote:why not just do a full charge - then a full discharge and see what the really are
i always done it that way - when cells arrived - i charge each cell full using 20A charge rate or you be there for weeks - and 20A is not alot to charge with -
then do a full discharge down to what ever you like - 2.5V or 2.9V - then do a full charge again -
each cell - build and charge with PL8 to balance -
unless the way i been doing it for past 6 years is wrong ?
steves1977uk wrote:Both sets of clips are directly connected on the cell's bolts.
Users browsing this forum: Bing [Bot], LROBBINS, tettralytic and 278 guests
