Programming leads
Re: Programming leads
Postby cositom » 08 Apr 2021, 13:46
invacare REM a/b this one is b it has light indicator functions though not on the chair
cositom
Postby woodygb » 08 Apr 2021, 14:01
The make and model of the control system attached to your ...or any wheelchair ...is the information that is required to provide you with the correct programming lead ,the relevant software and appropriate guidance to go with it.
So ...Can you post a picture of your joystick.
Postby woodygb » 08 Apr 2021, 14:16
OK.
https://invacaredocs.com/assets/documen ... 8b457a.pdf
NOTE:- Invacare owns the Dynamic control system.
What control system is on your Shop Rider?
I can provide a programming lead for £30 including postage.
YOU WILL NEED SOME EXPERT GUIDANCE TO HELP YOU IN MATCHING YOUR NEW JOYSTICK TO THE CONTROLLER.
Postby cositom » 08 Apr 2021, 15:02
cositom
Postby cositom » 08 Apr 2021, 17:01
woodygb wrote:The make and model of the control system attached to your ...or any wheelchair ...is the information that is required to provide you with the correct programming lead ,the relevant software and appropriate guidance to go with it.
https://photos.google.com/photo/AF1QipM ... ADZ3j463ak this one off shoprider
https://photos.google.com/photo/AF1QipM ... Qsg5b4jZJa this one off you-q invacare
couldnt upload pic
cositom
Postby woodygb » 09 Apr 2021, 01:39
The photos that you have linked to can only be seen by YOU.
Postby cositom » 09 Apr 2021, 12:44
ok i will try send other pictures
bbs
the shop rider chair i have looked all over it i cant locate controller or any badge that indicates operating system, i will see if i can do more looking around it. thank you kindly
cositom
Postby cositom » 09 Apr 2021, 12:54
these are the images of both machines, i included the invacare label off the machine in case needed
cositom
Postby cositom » 09 Apr 2021, 13:26
the closest model it shows to be shop-rider Lugano 888WNLL I have also attached images from shop-rider that all cables go to, I hope this helps, unfortunately I unable to find any other information of this machine at present,
many thanks, do I address you as Woody
cositom
Postby woodygb » 09 Apr 2021, 14:47
The first pic is a Penny and Giles Vsi 4 key.
The second is a Dynamic DX2.
The programming lead will have a switch to toggle between the 2 types.
Woody is fine .. :thumbup:
Postby gcebiker » 10 Apr 2021, 02:24
woodygb wrote:The first pic is a Penny and Giles Vsi 4 key.
Second is Dynamic Shark
gcebiker
Postby rover220 » 10 Apr 2021, 06:35
no it isn't, it is a dx2.
Postby gcebiker » 10 Apr 2021, 09:24
My bad, should have blown up the picture. :worship
gcebiker
Postby cositom » 11 Apr 2021, 00:55
had trouble finding the thread, that is good news perhaps pm me mr wood, we can arrange my ordering a lead thank you for your guidance
cositom
Postby cositom » 11 Apr 2021, 00:56
gcebiker wrote:My bad, should have blown up the picture. :worship
yep you bad lol
cositom
Postby TabascoFett » 14 Aug 2021, 12:44
Hi, I’m looking for a controller adapter to USB for a Pride Apex Rapid. I also am trying to get hold of the OEM software but not having much luck. The software is called PG MOBILITY - PC PROGRAMMER. Any assistance you can provide would be highly appreciated.
TabascoFett
Postby wheelchairer » 14 Oct 2021, 13:57
Hey Woody, do you sell these as well?
Has anybody built one of these, A XLR phone charger?
Do you have a parts list, and wiring design?
C4/5 tetra
wheelchairer
Postby woodygb » 14 Oct 2021, 14:55
wheelchairer wrote:Hey Woody, do you sell these as well?
Yes, I build them on request.
Postby Burgerman » 14 Oct 2021, 18:26
Postby raymondhutton88 » 25 Oct 2021, 16:15
Hi there how do I go about obtaining a Program lead from you for my VR2 90 am brain.
raymondhutton88
raymondhutton88
Postby woodygb » 25 Oct 2021, 16:30
Just ask,
Are you in the U.K.?
Postby Stitch » 16 Nov 2021, 02:56
Woody -
I would like you to build me a programming lead and it send to Wisconsin, US.
Jazzy 1450 SN JC528217038020
VR2 D51080.07 90 AMP Controller
VR2 6 button D50680.01 Joystick
I downloaded the PG Drives Technology PC Mobility Programmer Dealer level from the Amlior website through a link in this forum.
Still looking for the OEM level program.
I tried to attach some photos, but with even one got a file too large error.
Thank you - Steve
Stitch
Postby woodygb » 16 Nov 2021, 08:26
Email me nala_doow AT hot mail dot com
Postby shirley_hkg » 16 Nov 2021, 15:18
shirley_hkg wrote:woodygb, what is the proper connecting steps ?
I have the USB converter installed.
Plug in your lead. Joystick shows an inhibit.
Connect the other end to USB converter. Inhibit goes away. Is it normal ?
Launch Wizard, but see it is not connected yet.
Any advice ?
Is there a proper sequence of connection ?
Postby woodygb » 16 Nov 2021, 17:24
I think that any sequence will work.
HOWEVER...This is my normal procedure.
Plug in USB lead
Start Software...
Select Coms Port...
Turn ON Controller / Joystick
Wait while the DYNAMIC software searches for controller ... ( You can see the search bar in the bottom right hand corner )
Postby shirley_hkg » 18 Nov 2021, 11:48
Everything worked fine last year .
Try to program it last month but couldn't connect.
Today I tried again on another Win 10 laptop.
Same result , with endless scanning .
Any advice ?
Postby woodygb » 18 Nov 2021, 12:03
What controller ...what programming cable and is it possible that the device driver has updated in the last year?
Can you open up COM3 in device manager and show the driver version / date etc.
Postby shirley_hkg » 18 Nov 2021, 13:07
OK. Will check on it and return back . cheers Thanks.
Dynamic and lead from you.
Postby Burgerman » 18 Nov 2021, 13:24
For what is worth in windows 11 pro, and in windows 10 LTSC version it all works as expected.
Postby shirley_hkg » 19 Nov 2021, 01:13
Dynamic and the lead from you.
Will find out tomorrow , but it already said (ok , port in use) .
Users browsing this forum: No registered users and 79 guests
