Burgerman wrote:Are you SURE that chair can only fit 33Ah batteries? Thats way too small for both sensible range, and garantees the battery has a very hard life and so doesent last long.
If so then we need the battery type such as 22nf or grp24 or whatever. Or the physical size of the maximum that will fit to advise.
If the biggest batts really are 33Ah sized, and bigger wont fit then they designed a chair that will always have battery and torque problems. And probably uses the small U1 Deep Cycle sized batts.
Whatever you buy in U1 size, will struggle.
IF U1 are the only size that will fit you need these https://www.wheelchairauthority.com/MK- ... -sld-g.htm
bumbaloto wrote:Burgerman wrote:Are you SURE that chair can only fit 33Ah batteries? Thats way too small for both sensible range, and garantees the battery has a very hard life and so doesent last long.
These are the original batteries - AGM - M22NF SLD A 12V 55Ah C20.
They offer me these
Number of cells 6
Voltage 12
Capacity 33Ah at 10 p.m. at 1.80V per cell at 25 ℃
Weight Approximately 10.2 kg (fluctuation of + 3%)
Internal resistance Approx. 9.0 m2
Terminal F11 (M6) / F7 (M8)
Maximum output voltage 330A (5 sec)
Amperage for cold ignition 230A
Maximum charging voltage 9.9A
The question is whether they get up and whether they will not damage the wheelchair
I only use a wheelchair at home
Do not fit 33ah batteries unless you wish to spend your life worrying about range.
rover, says:
Haze hzy ev12 55 are the biggest you'll fit. 33ah much to small and will last 5 mins.
martin007 wrote:What battery charger do you have?
My recommendation is to place the batteries with the highest capacity (ah) that fit in the space provided for them.
martin007 wrote:Hi bumbaloto.
Can I ask you a question?
Do you have money problems?
Buying the 33ah batteries is a waste of money.
Cheap is expensive.
Dan wrote:What country do you live in?
Rover, a dealer said "Haze hzy ev12 55 are the biggest you'll fit"
Check measurements first.
https://www.bblbatteries.co.uk/product/ ... 9-7ah-gel/
I think Haze is a Chinese company.
rover220 wrote:Why are you not listening. I used to work for the uk importer of the Paravan chairs, I have fitted umpteen sets of the batteries I suggested, haze hzy ez 12 55
bumbaloto wrote:rover220 wrote:Why are you not listening. I used to work for the uk importer of the Paravan chairs, I have fitted umpteen sets of the batteries I suggested, haze hzy ez 12 55
Thank you man for your help and time. Just the size you offer worries me. - 229x138xh213mm
Is that what you offer?
https://www.blubattery.com/home/batteri ... gp.8018.uw
bumbaloto wrote:These are the original batteries - AGM - M22NF SLD A 12V 55Ah C20.
They offer me these
Users browsing this forum: Bing [Bot], LROBBINS, Raro, woodygb and 41 guests
