Burgerman wrote:If you charge a 200Ah pack from empty then 20A charge will take 10 hours. Then hal hour at CV/balancing...
So more is better!
fishinjunky wrote:if i have a 24v A/C psu can I use the regenerative discharge for capacity testing and for discharging for storage during winter. Or must it be D/C psu to be able to use regenerative discharge feature. Or can i hook my two 12v 70ah mk gel batteries in a series for 24v theN connect it to the second channel of the iCharger for discharging my 200ah pack into. ( im not concerned about the lead batteries health ) but for this to work would the lead battery im discharging into need to be equal energy to the 200ah pack im discharging?
Burgerman wrote:You would need some discharged lead batteries that were around double the capacity of your lithium to discharge them into the lead because of peukert. Unless you are also discharging the lead with say a dump load, or something at the same time... It gets complicated.
Burgerman wrote:Much more than 3 batteries!
You only get about half the Ah out of (or returned into) a lead brick in use because of peukert. So say 40Ah at the 2 to 3 hour rate from a 70Ah battery.
Why the 2 hour rate? Because you typically get 8mph x 2 hours = 16 miles range before you are out of juice.
So to equal the range of a fully usable 200Ah 24v from lihium (no peukert of chemical voltage drop), you need (200Ah div by 40Ah =) 5 TIMES the number of lead batts. So for 24v system thats 8 to 10 MKs...
Burgerman wrote:Most never actually run out of juice. Bcause they have a subconsious understanding of whats possible and it determines what they do o attempt. They behave according to whats "safe" daily. Without noticing that its controlling their behaviour. They limit what they do or where they go automatically. It takes months to throw that behaviour off. To reprogram mentally. To understand that you can go anywhere, even late at night to the town to eat/drink after a good days use. With no danger of ever being stuck or out of power.
Battery box has room left, after 8 of these 230Ah cells.
I'll incorporate both PL8 & BMS charging into my next pack.
Dsub + XT120 connectors.
My BMS need the 4 signal pins that SB50 couldn't provide.
Burgerman wrote:Very slightly... Be sure to set that charger to start balance only when ABOVE 3.50V.
Burgerman wrote:Yes thats correct.
Go through all its advanced settings. And set each accordingly to give the correct CC/CV current, voltage, termination current, balance start voltage, and all the rest. Dont miss anything that will catch you out.
expresso wrote:i hope once you master this new charger - it can be a replacement for the PL8 - sounds more complicated -
but theres no other choice now - hopefully you will master the charger and then teach the rest of us to use it one day also -
Users browsing this forum: emilevirus, Jay_x and 607 guests
