LROBBINS wrote:19.6 milliohm = 0.0196 ohm, within measurement error of the 0.01 ohm estimated from voltage and current - so, yes, that's OK. IR of 0.3 mohm is also perfectly acceptable.
fishinjunky wrote:I didn't realize just how important it is to keep all balance wires and charging leads as short as possible makes a huge difference. It's convenient but takes a 40 amp charge down to 20 amp with long leads an connectors. What's the max length you guys are using 6ft?
I'm thinking I could get by with 5ft
steves1977uk wrote: A ZXD2400 PSU would be better though!
steves1977uk wrote:fishinjunky wrote:I didn't realize just how important it is to keep all balance wires and charging leads as short as possible makes a huge difference. It's convenient but takes a 40 amp charge down to 20 amp with long leads an connectors. What's the max length you guys are using 6ft?
I've used 2 metre cables (balance and power) and still charge at 40A using 10AWG for the main charge cables.
steves1977uk wrote:I used to have an ex-RAF chap make up my charging cables and build my pack. It is annoying having to wait for others to help people like us to do the work. One of my PA's daughters is into engineering, so I'm hoping I'll be able to learn her how to solder.She managed to rebuild a motorbike from scratch.
Burgerman wrote:Being paraplegic I can do many things that need only hands. Inc soldering. Balance, getting stuff into position, dropping stuff that I cant pick up are my problems. Spasm kicks in while trying to reach things. Or to get into an odd position to see where I am putting a screw.
For e.g. I just built most of a complex heavy PC on my bed while in it. Its around 40lb now with a heavy case, heavy water blocks, glass sides etc. Everything done except the pipes and fittings. Thats hot air guns, junior hacksaws, files, templates, and manoevering that heavy case to get everything into the right position. I cant do this on my bed easily because of the sheer weight and balancing everything on me. instability. So a carer holds parts or the PC case in position etc. I do around 15 to 20 mins a day. Because thats not what they are paid to do... But we are getting there slowly. Today most of the stuff, scews, tools, etc was on the floor at least a dozen times. Its highly frustrating. I have the skills but positioning, balance (mine) and a lack of stability while balancing everything on top of me is the problem. But you learn to live with seemingly trivial things taking gargantuan effort and weeks in place of a couple of hours.
If you cannot use your hands at least normally it must be even worse. I feel for you!
sometimes I feel like a fish flopping out of water when they kick off
Burgerman wrote:CALB?
shirley_hkg wrote: Do not use those EVE_105 cells..
Their internal resistance will turn bad for no reason.
M4 thread hole made me crazy.
Learnt a lesson the hard way.![]()
Buy CATL.
LiFePO4 for Shanghai made TESLA . Will get 8 of below for my Storm4 Xplore .
Scooterman wrote:Sorry I can't remember how to insert a URL properly
https://www.aliexpress.com/wholesale?ca ... tl+lifepo4
Scooterman wrote:When I did finally uncovere it the packs volts had dropped down about 4 volts!![]()
It's such a shame as they were good cells (EVE 90Ah).
fishinjunky wrote:
this is where i purchased my 8 x 200ah cells. The lady was very helpful and responsive and easy to work with. The cells were grade A and tested full cap and correct IR. They have m6 welded studs
contact email for the lady
annette_ou@yabohybridbattery.com
listing for the cells i purchased
https://yabopower.en.alibaba.com/produc ... 755baSFmSp
Did you try to recharge them ?
No way to salvage them ?
I was worried about damaging the PL8.Return to Everything Powerchair
Users browsing this forum: acid_coke, emilevirus, JMGarage, sergey0, shirley_hkg and 147 guests
