chazzyr wrote:One for the programming wizards. My Torque 3g with Tilt/Recline is showing this error on turn on. I have to click twice on the mode button to get the drive, which is fine. The seat is stuck at a slight tilt. Is there any way to get the seat back to level? Thanks for help.
Burgerman wrote:My chairs have been set to 100% forwards acel since 1990... And I only have one profile. Rear drive.
http://www.wheelchairdriver.com/gopro/control.mp4 Why set it to go slow? It is proportional. It goes as fast or as slow as you instruct it. It accelerates as hard as you tell it too. Full control. You dont have to do as in the vid. Its mm perfect.
Okay. I was not being clear. I have torque set to a hundred in all profiles, anyway.
The higher you set this the higher the front casters lift up when you push the joystick at full throttle. But if you want the casters to lift up very high at slow speeds you have to set the max. speed low, otherwise it will never reach maximum forward acceleration when climbing a curb -- unless for some crazy reason you want to climb a curb at 10 km / hr. Thanks, you completely answered my question.
Scooterman wrote:I can set up additional profiles in r-net software and load them to controller. But I can't work out how to switch between the two drive profiles. I only want a main drive profile, and a second profile for manuevering empty chair into position indoors or on public transport.
Burgerman wrote:I dont know how on the LED joysticks you differentiate between modes, which seating funtions, or how to tell if you are changing drive profiles or speeds. Esp if outdoors where the sunlight means you cant tell what the hell is going on. With many modes, seating options, speeds, and profiles you really need a screen. Or its just a mass of frustration.
Burgerman wrote:I have both too. And I am not using the LED one for all the reasons mentioned but will on my non rehab seating BM2 chair in a few weeks. Both are great in he right situation.
The LCD ones are better here. But again too small screen, and not bright enough outdoors.
The metal based CJSM2 has a bigger clearer screen that allows you to actually see what does what, with dedicated buttons, and it is bright enough to see what speed/mode/profile you are adusting and how to switch into and out of each one.
With the basic LED ones like the vid, its best to have only one profile, and just set speeds from the slowest 1mph to the fastest at max speed. And really thats all you need anyway. And a basic non rehab style chair.
With the ones with a screen, I set TWO drive profiles, and one is for an empty chair, where there is just one speed, (same as SLOW speed on the main profile) and reduced load compensation.
And if you intend going out n the sunshine dont bother with the basic colour plastic joystick. It's not bright enough and screen a bit too small.
Oh okay thanks700R wrote:To alter your profiles you simply press the 'speed' buttons between the indicator buttons if you have profiles enabled in the software. If not those buttons will act as speed up and down buttons.
Burgerman wrote:So... How do you change the speed in each profile?
Users browsing this forum: LROBBINS and 160 guests
