Icharger X8 Settiings for Lifepo4
Postby Qvickster » 11 May 2022, 05:09
Anyone have any recommendations for charge settings?
Qvickster
Re: Icharger X8 Settiings for Lifepo4
Postby Burgerman » 11 May 2022, 09:16
How big is the lifepo4?
Postby fishinjunky » 11 May 2022, 13:25
Here are the settings I use for a 8s 200ah pack with a iCharger4010. But wait until BM comments agian before using these settings. He may recommend tweaking or changing them.
Charging 8 cells / size 200ah
CHARGING CURRENT: 30amps Max for the iCharger x8
CHARGING END CURRENT: 1% (1% is the lowest you can set)
CHARGING CELL VOLTAGE: 3.6V
CHARGING MODE: Normal balance
BALANCE START: cv -0.1 is what you set to start balancing at 3.5v if charging cell voltage is set to 3.6v
Go to charging mode click set beside Normal balance then select END CURRENT AND DETECT BALANCE
Leave capacity as IGNORE
leave ceĺĺ count as AUTO
Postby Qvickster » 12 May 2022, 00:55
105ah eve cells
Qvickster
Postby Burgerman » 12 May 2022, 01:20
The above will work, set to 20A.
Users browsing this forum: shirley_hkg, swalker, UnicornBurner and 53 guests
