ICEUK wrote:Fishjunky, are the flexible busbars copper wire in the middle or part of the busbar bent that way?
fishinjunky wrote:ICEUK wrote:Fishjunky, are the flexible busbars copper wire in the middle or part of the busbar bent that way?
They are made from 30 thin layers of copper bent in the middle an pressed òn the ends nickel plated. And insulated. But I would use bus cables an only use these flexible busbars as a last resort
fishinjunky wrote:200ah lifepo4 build for my bounder 300 chair. Replacing group 24 lead bricks. Everything is soldered and crimped.
8 x 200ah lifepo4 cells:
https://m.alibaba.com/product/160016167 ... om=Android
Charger: iCharger 4010 duo
https://www.progressiverc.com/products/ ... 0704167047
Flexible busbars:
( I strongly recommend using bus CABLES instead of these. I ONLY used these Flexible busbars because I didn’t have the head space for bus cables).
Insulated Flexible Busars
https://a.aliexpress.com/_mrM3EFs
Cable sizes:
Charging cables 8awg
Balance cables 16awg
Power cable 6awg
Micka7405 wrote:fishinjunky wrote:200ah lifepo4 build for my bounder 300 chair. Replacing group 24 lead bricks. Everything is soldered and crimped.
Flexible busbars:
Cable sizes:
Power cable 6awg
its just to know why you use the 4010 if you have an 8 cell pack instead of the 408
fishinjunky wrote:We really like the Anderson connectors they are a bit tight but mom can unplug them. I may have a few handle designs 3d printed to test an see if that makes it a little easier. But its fine if not.
Burgerman wrote:How do you run anything?
Many things are 3kw here. Everything from the over in your kitchen, the dryer, the washing machine, the hairdryer is 1800 watts, the thing I used to bend the pipes in my PC is 3000 watts, my fan heater is 3000 watts. My power supplies are 2200 and 3000 too And theres literally 18 sockets in this bedroom!
You should be able to get 16A at 110 volts at least. Thats 1760 watts. And have double that at 220V for heavy appliances. At least in the US.
Here and most of the world 240V is at every socket. And 3.1kw capable.
Micka7405 wrote:and can you charge 70 amps with 110v in the USA?
I can't here if I'm not going to burn all the children of the town
jefferso wrote:F5 if I get one
Waiting to see bulging cells too.
Prismatic cells are much less pressure tolerant than cylindrical ones .
1C charging is hypothetical in laboratory.. Reality , or Aliexpress , never comes close.
jefferso wrote:fishinjunky wrote:We really like the Anderson connectors they are a bit tight but mom can unplug them. I may have a few handle designs 3d printed to test an see if that makes it a little easier. But its fine if not.
Sometimes people doing my charging don't push the Anderson in all the way, but it had been working a long time before I realised they weren't pushing it all the way in. I guess if it's shoved in enough for the metal contacts to be pressed together it works. But I found some handles that help pulling them out, which helped encourage my helpers to plug them all the way in.
https://www.ebay.com/itm/303728486330
or UK https://www.ebay.co.uk/itm/131863789736
They also had little rubber covers / caps for the end in case dust or water might be a problem.
jefferso wrote:jefferso wrote:F5 if I get one
Looks like the F5 has the batteries side by side vs. the C500 divided end to end configuration. I guess if I get one made for the C500 I should configure the cells in two Group 24 sized groups which can be rotated to fit so I can switch it over to an F5 when the time comes.
Video of F5 battery change:
https://www.youtube.com/watch?v=fVWFgXAdvrY
Screenshot from that video:
fishinjunky wrote:Just out of curiosity why get a permobil f5?
jefferso wrote:fishinjunky wrote:Just out of curiosity why get a permobil f5?
One thing I have some concern about is centre of gravity. Looks like the cells are "about 4.12kg" so 8 would be about 33kg vs about 47kg for the MK Gels. With the extra weight of the standing feature up top, I'm not sure whether losing 14kg down below will make a noticeable difference to stability.
I've been using this Permobil C500 with standing for nearly 12 years so I'm used to it and F5 seems to be the closest thing. More detail in this old thread.
https://www.wheelchairdriver.com/board/ ... 57#p174257
jefferso wrote:One thing I have some concern about is centre of gravity. Looks like the cells are "about 4.12kg" so 8 would be about 33kg vs about 47kg for the MK Gels. With the extra weight of the standing feature up top, I'm not sure whether losing 14kg down below will make a noticeable difference to stability.
foghornleghorn wrote:jefferso wrote:One thing I have some concern about is centre of gravity. Looks like the cells are "about 4.12kg" so 8 would be about 33kg vs about 47kg for the MK Gels. With the extra weight of the standing feature up top, I'm not sure whether losing 14kg down below will make a noticeable difference to stability.
15mm thickness of roofing lead sheet in the bottom of the battery box will make up your lost weight and put it lower down for extra stability.
Users browsing this forum: mentado020477, shirley_hkg and 32 guests
