Check the wiring continuity from the controller to the XLR socket and check the power cables too the controller ( black box ) from the batteries.
That is more than likely your problem.does not perfectly touch the pins.
You can easily recognize that's abnormal, cannot you? Is the YELLOW CONNECTOR guilty of this fault? I mean it only physically matches the 4-pin socket but does not perfectly touch the pins. I note that the original 4-pin connector is usually GRAY.
snaker wrote:To solve this problem, I will need an adapter cable to exchange 4-pin YELLOW CONNECTOR to 4-pin GRAY CONNECTOR, right? Do you know anywhere that is selling that adapter cable? Or do you know if those 4-pin YELLOW CONNECTOR and GRAY CONNECTOR have technical names? So I can google them.
Burgerman wrote:https://www.aliexpress.com/item/2251801798283873.html?gatewayAdapt=4itemAdapt
I would use these.
Users browsing this forum: LROBBINS, martin007 and 71 guests
