Where to find PGDT programmer software
Re: Where to find PGDT programmer software
Postby woodygb » 19 Mar 2022, 13:50
I use Windows 10 and have previously used all the Windows variants without issue.
Postby AlasiaMedium » 20 Mar 2022, 15:32
The controller is the 45A S-Drive.
I built the cable on my own. It uses a CH340E.
Schematic:
The controller is answering. But for some reason it gets a timeout on the port. I dont know what causes this. If its the PC programmer or some driver issue, or what else it could be...
AlasiaMedium
Postby woodygb » 20 Mar 2022, 17:08
Use one of these instead of the CH340
FT232RL FTDI Mini USB to TTL Serial Converter Adapter FT232RL USB to Serial Mini USB to TTL Adapter Board
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
Postby AlasiaMedium » 21 Mar 2022, 17:19
Nope. No Change. Same old Status_Timeout. I think my Controller has some type of problem....
AlasiaMedium
Postby woodygb » 21 Mar 2022, 18:30
Try the Industrial software ..it is in my experience more forgiving with the signal.
Check your Messages.
Postby AlasiaMedium » 25 Mar 2022, 15:01
Thank you so much Woody. The industrial version works. It seems this version uses another set of commands to access the USB port. I dont know why the one the other version uses doesnt work. But who cares. I got what I wanted. Thanks again :)
AlasiaMedium
Postby woodygb » 25 Mar 2022, 15:18
:thumbup:
Postby Lleksam » 05 Apr 2022, 22:26
Hi All
looking for some help or information on re-programming a SOLO controler, from a PowaKaddy for a bit of a runnaround have used gokart wheels that are near 2" diameter smaller than what was on it, and 8 105a Lifepo4 cells (on way from China)
doing something wrong cant post immage
Thank you
Growing Old is not a option BUT growing UP is
Lleksam
Postby woodygb » 05 Apr 2022, 22:29
The SOLO controller requires the Industrial Software.
Postby Lleksam » 05 Apr 2022, 22:45
woodygb wrote:The SOLO controller requires the Industrial Software.
Thanks Woody, Is it obtainable any where? and i have seen a drawing on a FTDi Friend???? where is best place to obtain one, hate software cant poke it with a screwdriver or teach it a lesson with a hammer
Lleksam
Postby woodygb » 05 Apr 2022, 22:56
The pic below shows the connections using an FTDI cable , with the addition of a resistor and Schottky diode ...
BUT a direct connection ( TX of USB to RX of controller ) and ( RX of controller to TX of USB ) plus GND will probably work.
Postby woodygb » 05 Apr 2022, 23:10
CHECK YOUR MESSAGES.
The plugs on this cable should... as I recall.... fit the SOLO and as a bonus only fit one way.
NOTE THAT THE POSITION OF THE WIRE COLOURS WILL NOT MATCH THE SOLO ...You can however press down on the tags and swap them around / remove them.
https://www.amazon.co.uk/rhinocables%C2 ... 9VJT4?th=1
Postby Lleksam » 05 Apr 2022, 23:14
Thank you, I have just bought resistor, diode, 1:4 lead and a FTDI friend from PI HUT
Thank you for your help I have been dredding this bit and still am
Lleksam
Postby eupduck » 13 Jun 2022, 21:51
Hi I too require a copy of s-drive software I have trouble with a replacement controller for my vita sport . The replacement appears to not behave as it should . If any members can help with software, many thanks in advance. Wes
eupduck
Postby mrgus2u » 20 Jun 2022, 19:15
I am also looking for the PG drives oem software for my S-50 controller. I have the dealer software, but it doesn't give me access to many parameters.
mrgus2u
Postby Burgerman » 21 Jun 2022, 10:17
check pm...
Postby bhuja » 14 Jul 2022, 11:37
I was also looking for a copy of the industrial PG drives programming software.
Thanks in advance!
bhuja
Postby bhuja » 14 Jul 2022, 12:20
woodygb wrote:The pic below shows the connections using an FTDI cable , with the addition of a resistor and Schottky diode ...
Just making sure I am not interpreting this incorrectly, so where the charger usually plugs in to the controller can also be used to program the controller?
bhuja
Postby woodygb » 14 Jul 2022, 16:33
MOST of the time ...but not always.... there is no harm in trying.
Postby chookey » 21 Jul 2022, 13:50
mrgus2u wrote:I am also looking for the PG drives oem software for my S-50 controller. I have the dealer software, but it doesn't give me access to many parameters.
I have attempted to change a parameter in my s-drive controller. It came up with 4 warnings of parameters that I couldn't access.
I felt the controller itself was prohibiting access. Am I wrong? I'm using the OEM software. If I could get hold of the Industrial would I be able to access all?
The parameter I wish to change is the pull away delay. It may seem petty but that small delay between operating the throttle and actually moving quite annoys me czy
I made my own cable up for programming and eventually got there. There may be other changes I would like to make as well but the aforementioned is a priority for me.
Would appreciate any help/ advice on this :worship
chookey
Postby woodygb » 21 Jul 2022, 15:02
The industrial software will not help.
Can you post your saved parameters file either with the .prg extension changed to .zip or as a zip file.
Changing the motor compensation could help.
Should you wish to try it yourself, make alterations in SMALL 5 STEP INCREMENTS ...going too far can cause a RUNAWAY motor / scooter.
Postby chookey » 21 Jul 2022, 17:42
Didn't think it would woodygb but was worth an ask.
Been offered another 120A controller which is supposed to be completely open but didn't really want to go down that route. Just spent 2.5k on the scooter.
I've attached my saved dump. I did change the max speed slightly just for the hell of it. Was originally set at 98%
factory.zip
(570 Bytes) Downloaded 263 times
chookey
Postby woodygb » 21 Jul 2022, 17:55
You have a P.M.
Postby Mechanicc » 07 Sep 2022, 19:30
Hi everyone
My name is Patrick from Quebec Canada and I am fairly new to the s drive controller World.
Im planning on replacing a water damage sdrive 120amp controller for my scooter.
I have been reading your forum for the last week, i made my cable following your instruction and on my first attempt i blew my laptop motherboard by connecting the power connector of the cable to the controller :(
Thank you very much for all the valuable info found here and what a great job you do by keeping us very well instructed and with an English i can understand because this isn't my primary language and i believe i pretty well understand what i read so far, so thanks a lot
What i am looking for is the oem version of the software for PGDT programmer.
Thanks a lot
Patrick
Mechanicc
Postby woodygb » 07 Sep 2022, 21:49
Your motherboard and the 24v pin of the MOLEX hanged ..... plus the USB TTL Adapter is also toast.
You have a P.M.
Postby woodygb » 07 Sep 2022, 21:55
Im planning on replacing a water damaged sdrive 120amp controller for my scooter
...Are you sure that the S-Drive controller is water damaged?
Postby RezaV » 13 Oct 2022, 11:54
Hello
I am also looking for the PG drives oem software for VR2 controller. I have the dealer software, but it doesn't give me access to many parameters.
best regards
RezaV
Postby Burgerman » 13 Oct 2022, 13:07
Check PM
Postby eugenech » 22 Feb 2023, 22:06
Looking for VR2 OEM version. Please help.
Thank you
Eugene
eugenech
Postby Burgerman » 22 Feb 2023, 22:42
PM me. I will give you a link.
Users browsing this forum: Juggler258, LROBBINS and 566 guests
