Any info on programming this one is appreciated.
Can it be programmed with the 1314 software? Or do i need the hand programmer? Is there a Curtiss controller, but microprocessor based, that can replace it without changing the harness?
woodygb wrote:As far as I am aware the 1208 is not programmable.
http://liftpartsrus.com/Controls-all/1208%20Manual.pdf
Replacing it with a another make / model will entail changing the part of the wiring loom that plugs into the controller.
The Curtis 1228 or a Penny & Giles ( Curtiss Wright ) S-Drive are both suitable replacements.
https://cdn.curtisinstruments.com/produ ... eet_en.pdf
https://davilot2.ccvshop.nl/Files/10/26 ... manual.pdf
....I simply search the web.Where do you get these manuals from?
woodygb wrote:....I simply search the web.Where do you get these manuals from?
mrgus2u wrote:Any info on programming this one is appreciated.
Users browsing this forum: Gregg and 101 guests
