Postby steves1977uk » 27 Aug 2022, 14:27
I always leave the banana plugs and balance plug connected to the PL8 SM, that way no shorts can happen.
Postby LROBBINS » 27 Aug 2022, 16:28
I use a dab of Goop on bananas, balance and serial connectors so they CAN'T be accidentally disconnected.
Postby Burgerman » 27 Aug 2022, 18:05
IF you are using the correct banana plugs, the only ones that work safely and dont melt, you cant get sparks. They are intrinsically safe, shielded ends. Thats why you are recommended these with a PL8 and why you should use them.
Unless you actualy plug one onto the rear of the other! But then your 40A fuse will blow. There should be one in the neg, and the pos cable.
Postby steves1977uk » 08 Oct 2022, 16:29
Got my second PL8 from Shirley yesterday. Thanks Shirley! :thumbup:
Postby shirley_hkg » 09 Oct 2022, 03:51
Burgerman wrote:That's a really slow boat ! :shock:
Very true !
Luckily not A single one of the 9 units I shipped were lost in transit , there is still one at sea though. ;)
steves1977uk wrote:Got my second PL8 from Shirley yesterday. Thanks Shirley! :thumbup:
:o Good grief ! It was sent in the early of June .
The world is getting SLOWER … SLOOOWER … … and … … SLOOOOOW …e … r.
Hope it won't stop completely .
Postby shirley_hkg » 09 Oct 2022, 15:50
Burgerman wrote:HK to london. 5995 miles.
135 days is 3240 hours. Thats 1.8503 mph
Average walking speed is 3.8 mph. So if someone walked it would have taken half as long. :lol:
Its literally traveled at the same speed as a decent tortoise.
Or some 135 times slower than TNT overnight delivery.
Postby shirley_hkg » 26 Feb 2023, 06:12
Got 2 very nice, nearly brand new, PL8 this week.
Tested to ensure they are free from incorrect voltages of the 8 balance pipelines. I've came across 5 units which had the problem, so a proper one is scarce.
Postby shirley_hkg » 26 Feb 2023, 06:16
Another one.
Charged the same battery a bit, so voltage is not the same.
Postby Gnomatic » 26 Feb 2023, 20:35
thank you shirley!
Postby shirley_hkg » 02 May 2023, 04:00
How to change to 3 decimal ON THE PL8 ?
Postby shirley_hkg » 02 May 2023, 05:04
We've never done such on the charger itself. Don't laugh .
youtu.be/fNHwYR4WkRM
Postby Burgerman » 02 May 2023, 07:41
I always use PC and dont think you can.
Postby shirley_hkg » 02 May 2023, 09:11
Found a NOS and want the seller to show me the voltages. He don't know how as he's never used it and don't have the FUIM3.
Postby Burgerman » 02 May 2023, 10:24
NOS?
The number of digits may require that you have one of the registry hacks on a PC in order to change it.
2 options.
a)Averaged data so it looks all neat and only a couple of decimal places. Makes pretty graphs and unless something is actually wrong its stays this way but its not real! All good for a typical hobbyist without alarming him for no good reason.
b) an extra decimal place 4 decimal digits. And no data averaging so it shown reality. And also shows the caibration differences between cells. Or charger innacuracies too. Usually you would never see this as most people dont have the registry hack that allows it. And I dont think it can be changed on the charger.
Postby shirley_hkg » 02 May 2023, 12:13
Burgerman wrote:NOS?
New Old Stock !
I have your CCS , that can display 4 place of decimal . cheers
Postby Burgerman » 02 May 2023, 12:37
In your picture no,s 2 and 4 dont showthe V at the end?
Postby shirley_hkg » 02 May 2023, 13:36
No.
It has factory default value @ 2 place of decimal , as he never used it.
I am telling him how to test and show me that his charger doesn't have irregularities in reading voltages .
If it is fine , I am buying it. Someone here wants PL8.
I've seen a few units that were not right .
Postby shirley_hkg » 02 May 2023, 16:27
Burgerman wrote:In your picture no,s 2 and 4 dont showthe V at the end?
Yes. They do ..
Postby Burgerman » 02 May 2023, 16:43
Postby shirley_hkg » 03 May 2023, 01:53
It's fine now . No (V) at the right ends .
Postby shirley_hkg » 14 May 2023, 03:15
Hard to keep up with the demand of good working PL8, but to let go of my own collection too.
Postby shirley_hkg » 17 May 2023, 10:15
Normal shipping is resuming.
3 ZXD and 3 PL8 with accessories of total weight 20kg were dropped off at DHL shop last Friday evening.
They are now on the bench of member at California, 4 pm Tuesday local time.
20kg @$130.
Postby UnicornBurner » 24 May 2023, 04:45
Hey, there’s our workbench. Thank you Shirley! Everything arrived quickly and beautifully wrapped. You have been so very helpful and we really appreciate it! We are waiting for a few more supplies to come in and we will begin our journey of building our first set of batteries…..and then the questions may come pouring in.
Here’s the first, what is the maximum current/Amps output for the ZXD 2400?
Thank you! :D
UnicornBurner
Postby shirley_hkg » 24 May 2023, 05:30
50 amp @220V AC
31 amp @117V AC
Postby Burgerman » 24 May 2023, 11:14
And I use it at 50A (actually reads 49.xx) all the time when charging lead. Works fine!
But like most industrial stuff its a bit louder than a mobility charger. But when you consider that its 50A and not 5 or 8 its not a surprise! Its over 6x more powerful. 50A@28.8V= 1440 watts. And because 90% efficient it needs to lose 10% of that as heat. 144watts?
And remember it can do this at 60V and so 3000 watts... So would need to lose 300 watts of heat in that case!
Postby shirley_hkg » 27 May 2023, 12:04
woodygb, do you mind telling me is this interlink suitable , and what is the wiring method .
I have a corrupted PL8 to try it out . Nothing to lose.
Postby shirley_hkg » 27 May 2023, 13:50
The 5V is taken from usb , rated 100mA for external load.
Postby woodygb » 27 May 2023, 16:03
Try joining RX and TX of the MZ-RS24T = White of existing PL8 plug
GND of MZ-RS24T = Black of existing PL8 plug
DO NOT CONNECT RED of PL8 OR 5V of the MZ-RS24T:
Postby woodygb » 27 May 2023, 16:16
Another possibility with the addition of a schottky diode.
Re: PL 8 - Q and A section - How to S[b][i][sizeet up - Use
Postby shirley_hkg » 29 May 2023, 02:38
Thanks woodygb.
I'm ordering one @£13 for trial.
Users browsing this forum: acid_coke, rover220, Seafighter, Superchunk and 129 guests
