by wheelchairer » 30 Nov 2022, 12:43
R-Net settings.
1. Is there a way to stop the beeping when you have pressed the mode button and are scroling through standing sitting et cetera?
2. I am a C 4/5 tetraplegic. This is the 1st time I've had the assistance and time to properly go through the settings. And I must say, it is worth the effort.
I generally used to hit the doorways a little bit when I was rushing, and particularly when there was somebody walking behind me LOL. However, since setting the programme up like this, I really do appreciate getting the fine tuning right.
I do have 2 profiles "indoor" and "outdoor". I find this very good because there is just one button to press to switch between driving out and about, and when I get to my front door and coming in. And then there is the fine tuning for indoor and outdoor you can do. So for just driving around the house I will have it on the indoor profile on the highest speed setting. And then when I want to drive about with the drink on a tray on my knee without spilling it, I will put it on 1 of the lowest settings. And then when I'm struggling to get under a table, putting it on the slowest speed enables you to do so without knocking on the glasses everywhere.
Again on the outdoor, I generally use the highest speed but if the pavements are a bit rough for whatever I can knock it down a couple of speeds. Without going right down to the indoor speed.
I have it setup like this in both of my wheelchair is and find it very satisfying. Thanks for your help.
C4/5 tetra
