have 2 hypothesis
first hypothesis is that all this snow makes it hard for the motor to push and might be similar to be going uphill in winter condition for a long time. Maybe there is a temperature cut off in the motor to prevent the motor to burn. does anybody knows if such a protection feature is in this chair?
my second hypothesis is about water, the cars passing me by were splashing me a lot so maybe there is a protection feature is water goes into something, is that possible?
Burgerman wrote:I raised all mine on pilot plus systems to 70C too. They still roll back if you torture the chair. Mine have been doing that 70C rollback at least weekly since '95... Yet to have one fail.
On modern day chairs using r-net its not adjustable even on OEM software. So you are stuck with its 55C setting. But lower impedance mosfets mean its less of an issue. You can still make it do it easy enough though.
yeshelp wrote:Hi everyone
life being life i had another winter problem with the same 646 se wheelchair:
I was going up a medium hill in 4 th speed. i was giving medium joystick power keeping the speed low (maybe i reached a peck inadvertly) but all of a sudden the joystick light stopped and so did the chair...
I waited 30 minutes and tried to disconnect the joystick and reconnect without success.
Any idea what the problem is and how to solve?
