mini sauce
Burgerman wrote:mini sauce
- Code: Select all
a mini salsa chair
I also have relatively small home. Doesent stop me doing wheelies and 10kph indoors ALL THE TIME!
Yes I know you cannot do this. But the vid is just to put things into pespective and entertainment! I also mostly use FULL STICK like an on off switch.
You wouldnt like this!
Burgerman wrote:I need to see you control it in every direction and situation, fast and slow dont care if its indoors or out.
I joined up those videos to make one lowr resolution smaller one. It doesent affect you as you have the correct type. It shows the difference between the ROUND gate restrictor plate that we need, and the square one that is needed for aircraft or cars etc. For those that never considered this.
http://www.wheelchairdriver.com/gopro/JStypes.mp4
The ROUND one means that if you are going fast, you cannot add much turn, without that also slowing down the chair. It restricts the steer sensitivity at speed.
The SQUARE one is horrible on a powerchair because it means you can add full left stick while flat out! Causes wheel to screech or the chair to swerve violently left or right. This CAN be moderated with a software "gate" restrictor. If one exists. It DOES exist in a good RC transmitter as you need this in a helicopter. Or in the event of a tank steered vehicle. It can be added in some wheelchair controllers via programming too. To a degree.
http://www.wheelchairdriver.com/gopro/JStypes.mp4The ROUND one means that if you are going fast, you cannot add much turn, without that also slowing down the chair. It restricts the steer sensitivity at speed.
Burgerman wrote:Need decent video. So I can properly understand what is going on here. Because non of what you are saying is making any sense after FIVE pages of posts!
Burgerman wrote:Get someone with a video camera or smart phone to do a 5 minute video or a few shorter ones of you driving your chair in, and ouside of your home. Show me everything. Point out where you dont like/problem.
Steering, starting, stopping. Going through doorways, avoiding obstacles, traveling fast, slow. Show the whole chair. Show the joystick and you using it. Etc.
So I have as much info as possible. So I can see the WHOLE BIG PICTURE! Use the settings I gave you earlier in this thread unaltered.
I could not take video, because the chair on the outside is in driveable for me, with the test settings.
speed 5 the chair goes left and right too fast and swerves I had to stop it to regain control
That sounds like a description of very slow turn acceleration to me.
Burgerman wrote:No movie?
Those settings are dangerous. Back to why you posted the first time 5 pages back. Also those settings have reduced turn sensitivity beyond any rational way to steer. I am actually surprised it turns at all. This is not the answer. What you have dne is basically stop it steering at all! And if it does it is going to accelerate the turn to a miniscule 5% after about 5 seconds. Thats crazy.
Do a video so I can see the problem you are trying to mask.
Burgerman wrote:It was important because I did not know the type of gate/rstrictor. That makes a simply huge difference to you if you dont have good hand control. Because it either allows you to add max turn while travelling forwards or it does not!
But this was just a small part of this puzzle. I need to see you struggling to control the chair. From all angles and in the worst conditions. Because non of it is making any sense right now. Hence the video!!!
Users browsing this forum: No registered users and 89 guests
