q700m wrote:please list your requests like this
1) Take a video
2) Take a video
3) Take a video
so I understand what you want to know
thank you very much
1) Take a video
2) Take a video
3) Take a video
thank you very much
daveonwheels wrote:i believe he means elderly 'anziano'
Burgerman wrote:Several people inc myself, lenny, have suggested shaped restrictor plates on maybe 10 different posts. But so far we just get the standard nonsense about reducing compnsattion and setting everything to 1...
So?
Front Wheel Drive Type selects specific specialist software for front wheel drive wheelchairs
If Front Wheel Drive Type A, this parameter electronically alters the shape of the joystick gate. This has the effect of damping the turning rate of the wheelchair between the 9 o clock and 3 o clock joystick positions.
If Front Wheel Drive Type is set to B, this parameter sets threshold which, if exceeded, then both forward and turn speeds are reduced, but the turning radius of the wheelchair remains unchanged. Type B can be used to increase the steerability of the wheelchair at speed.
Front Wheel Drive
Front Wheel Drive adjusts the operation of the specialist software for Front Wheel Drive Wheelchairs.
This selects specialist software for front wheel driven wheelchairs.
The programmable range is 0% to 100% in steps of 1%.
If set to 0%, then “normal” software for rear wheel driven wheelchairs is employed.
If set to any other value then front wheel drive software is employed. A higher value makes the software more suitable for faster wheelchairs.
Advanced Electronic Stability
Advanced Electronic Stability sets whether the specialist stability software is turned on.
If set to On, AES detects if one wheel is running at a higher load and hence is running more slowly. If so, the speed of the other wheel is reduced accordingly to compensate for any steering offset.
AES can be used to minimize front wheel drive spins, fish-tailing and veering, both on the level and on a camber. The overall effect is to compensate for the wheelchair’s centre-of-gravity being shifted from the axis of the drive wheels, as is the case on front wheel drive chairs.
If set Off, then the function is disabled.
AES Rate
AES Rate sets the rate of adjustment of Advanced Electronic Stability.
This sets the rate of adjustment between the wheels under uneven loads. The recommended value is 55% and should not be adjusted without consulting PGDT.
A lower value will increase the strength of AES, which could result in the wheelchair feeling “twitchy” on turns.
The overall programmable range is 40% to 100%.
Burgerman wrote:These are all obvious by "feel" to me. However the way you use a joystick I doubt you wil be able to feel what is actually happening. A RESTRICTOR plate for your joystick will give you much more control. But you keep refusing to reply or talk about it.
q700m wrote:only Front Wheel Drive = 100%
I solved, it is as if I had lowered the engine compasation
Burgerman wrote:It does not lower compensation. It REDUCES turn rates when the stick is fully forwards. You said it made it worse!
Anyway, you have not solved it. You have made a bad situation slightly better. But you still dont have any proper control. You must see an expert that will take the bull by the horns and do whatever physical changes, input device changes, gate shapes, etc and changes to the chair that you need. Because removing the ability to turn at speed is maybe making it possible for you to move around in a straght line. But thats not really good enough.
Now do a 5 minute video of you driving in various places and conditions.
Front Wheel Drive
Users browsing this forum: snaker and 75 guests
