Linx access key
Linx access key
Postby Derky » 06 Feb 2024, 18:15
Hi guys I'm looking for advice and help I have spectra 3 wheelchair and have added attendant control but not working I'm assuming it's not plug and playing and needs programming in if so does anybody know anyone selling a lak please
Derky
Re: Linx access key
Postby shirley_hkg » 07 Feb 2024, 16:20
Re: Linx access key
Postby Burgerman » 07 Feb 2024, 21:51
Hopefully the easy to buy dealer version allows this. Because the OEM version is not available...
Re: Linx access key
Postby martin007 » 07 Feb 2024, 21:53
The price isn't low...
Re: Linx access key
Postby Derky » 09 Feb 2024, 09:35
Can it be programmed without lak and a direct lead from chair to computer I've got a lead just no software
Derky
Re: Linx access key
Postby foghornleghorn » 09 Feb 2024, 15:22
Derky wrote:Hi guys I'm looking for advice and help I have spectra 3 wheelchair and have added attendant control but not working I'm assuming it's not plug and playing and needs programming in if so does anybody know anyone selling a lak please
LiNX compact remote joystick needs programming in.
All others should be plug and play.
Are you switching the system on correctly? Joystick where power button wakes system is the only one active.
Power on with front joystick - only thing the rear joystick can do is turn power off, no steering or moving.
Power on with rear joystick - only thing the front joystick can do is turn power off, no steering or moving.
Derky wrote:Can it be programmed without lak and a direct lead from chair to computer I've got a lead just no software
DX-HHP can do some very basic programming on Linx system connected by cable and adapter. Not enough to add a control module.
Re: Linx access key
Postby Derky » 10 Feb 2024, 11:59
Yes I've added attendant control so will need to be programmed then I've got a lead but not sure we're to source software or someone local to Nottinghamshire that can do it for me
Derky
Users browsing this forum: No registered users and 5 guests
