Burgerman wrote:I may be tempted to TRY a set of these in a GRP24 chair. These are just big enough Ah to make it worthwhile, and while I dont like BMS equiped batteries for LFP cells, or powerchairs for that matter, these are at least capable of engine starting so should be OK with heavy intermittent currents...
Note that they are supposed to be GRP24 but are 2 to 3mm wider (275 or 276mm) than say a typical GRP 24. Not normally an issue.
Burgerman wrote:https://www.energy-xprt.com/products/da ... ery-923536
Burgerman wrote:Do careful measuring. Not all cells need to be the same way around. In many cases where there is a group24 setup originally its possible to fit 8 230Ah cells. Such as these.
There many suppliers. These for e.g will or should fit.
USA https://www.docanpower.com/index.php?ro ... ption=true
EU/UK https://www.docanpower.com/index.php?ro ... ption=true
swalker wrote:Every 230 Amp Hour cell without studs I have l0oked at is still too tall. They will otherwise fit in the F5 (requires a bit of an unusual arrangement of the cells, but that is OK), but they will not fit in the C500.
Burgerman wrote:Theres many variations on aliexpress. Like https://www.aliexpress.com/item/1005006 ... ry_from%3A and we cannot know. Look for lots of good feedback!
Burgerman wrote:Why would they be on their sides?
Users browsing this forum: Bing [Bot], Jay_x and 87 guests
