Postby yeshelp » 16 Mar 2024, 22:42
HI about the lithium conversion and Airplane, what do you experience?
Gel is knowed to be safe so no probleme to go into airplains.
lithium they dont like that already , if on top of it it is a diy battery wooo i wouldnt be surprised that they dont let us aboard or ask for the battery to be certified by a specialised shop.
Plus if it is a 230Ah battery, maybe it is to many Watthours beyond their limits.?
let me know about this issue please
yeshelp
Postby Burgerman » 16 Mar 2024, 23:03
No idea they keep changing the rules. But LiFePO4 does not burn even if overcharged or shorted ut or punctured. It will only burn if heated severely in some external fire. Lead/Gel batteries on the other hand give off hydrogen and oxygen which is explosive in a confined space if shorted or overcharged or old and faulty. So this type of lithium is actually safer than lead. Airlines dont understand this and so all get tarred with the same brush...
Its definitely too many watt hours for a REMOVABLE battery. But I think a non removable one has no limit. But I dont fly so cant tell you what they will do. Dont tell them.
Postby LROBBINS » 16 Mar 2024, 23:16
Burgerman is correct - there is no size limit for NON REMOVABLE lithium batteries. Last year we traveled Florence to Paris to Seattle to Orlando to New York to Amsterdam with 205 AHr LiFePO4. We had LOTS of problems (lost reservations to start with), but non regarding the batteries.
Postby yeshelp » 16 Mar 2024, 23:36
good to know , if anyone had problems concerning airports and their LIFEPO4 Diy please share it so we are more aware of the risks and or ways to pass through the system inspections.
00000000000000000000000000000000000000000000000000000
hum i think i begin to understand that pl8 v2 needs a power supply to work.
If i have to use temporarly gel batteries mk 73Ah with a pl8 plus a power supply, how noisy will that be ?
i read somewhere not to charge mk gel to more than 15 pourcent of total capacity to avoid gamification(a word like this)
how long would it take to charge the chair and would both psu fan and plu8 fan stop automatically?
maybe at a low Amps the fans dont have to run?
Any good bang for buck psu not too noisy to recommend?
yeshelp
Postby Burgerman » 17 Mar 2024, 12:05
You can swap all parts. Remember only fools and horses? Trigger was asked how long a brush lasted. He was a road sweeper. He worked as a road sweeper for 30 years. He said he still had the very same brush. When questioned further he said "well its had a lot of new handles. And about 9 new heads. But was the same brush he started with.
Postby shirley_hkg » 14 Apr 2024, 09:49
Bought some 130 Ah cells for a lady's Nutron RX51, replacing 22NF lead bricks.
Internal Resistance 0.28---0.30mΩ.
130Ah was recorded, and voltage difference was at the last 2,3 ah.
Put back 131Ah, and finished with nearly no dv at all. (I zoom in the last part of recharge)
LiFePO4 is cheap and high quality now. I paid £0.1279 for every Ah.
Postby Burgerman » 14 Apr 2024, 11:22
Those look pretty good.
Any link to the cells?
A 22NF gives a tiny amount of usable Ah. Around 25Ah until you actually grind to a halt.
So these wil bump that up to around 5X as much range as stock. Or 4x as much, but with a complete set of fully charged lead bricks left unused in reserve! :clap
Postby steves1977uk » 25 Apr 2024, 19:52
Hi all,
I'm looking for some 230Ah Grade A cells for saker98's chair. He's letting me keep the EVE-LF105 ones which I can use in the Groove chair I'm rebuilding if I can get them to balance correctly. What's the best website to purchase genuine Grade A cells please.
Thanks,
Postby steves1977uk » 25 Apr 2024, 20:02
UnicornBurner wrote:Thank you BM for your observation about our ability to use 230ah batteries. We did not think they would fit, but low and behold the EVE 230ah do fit in our Jazzy/Quantum Q6 chair. And yes FJ, I did quickly ask my hubby to upgrade to 230ah.
Luckily the EVE 105ah did not go to waste, we were able to install them in a chair our friends use that takes U1 batteries. So if anyone out there uses the little chairs that take U1 batteries, the EVE 105ah will fit. You will need to make two packs of 4 EVE’s and an extended cable to connect them. It’s a tight fit, but a great lifep04 solution for small chairs.
Thanks you again to you all for your support and excellent observations. cheers
What are those M4 terminal connectors you have used please? I have the same cells here.
Postby Burgerman » 26 Apr 2024, 12:55
What are you looking at?
Postby UnicornBurner » 27 Apr 2024, 22:40
Hi Steve,
We used m4 X 16 set screws. The nuts are m4 locking nuts. The connecting wires are home made by us. The wire we used is #8 flexible battery cable and we soldered the terminals on and covered the solder joint with sharing wrap tube.
Is this what you were referring to? These were for our chair that uses U1 batteries and we converted to Eve 105ah.
UnicornBurner
Postby UnicornBurner » 27 Apr 2024, 23:04
Also, we are on a new adventure. We are converting our trailer/caravan to lithium. We are installing 4 12volt batteries ( 16 Eve 105ah batteries total.) As this will not be charged by a PL8 with 40amp power source, we are not sure if we should attach an external BMS. :shock: :argument
We have a 75amp Powermaxx to charge with. These are the sort of charger converts used in trailers/caravans. https://powermaxconverters.com/product/ ... 20Shopping
We are working on a way to have 2 selectable voltages using 1 resistor and a switch as others in DIY conversions have done. One charge will be at 13.2 v and one at 14.2v depending on our charge needs. This BMS was suggested. https://srikobatteries.com/product/smar ... gJ0ePD_BwE
I know BM says NO BMS for the chairs, but do you think it is advisable in a trailer/caravan that will only be used a few times per year and we will not be able to go the PL8 route. Yikes! :shock: :shock: :shock:
UnicornBurner
Postby Burgerman » 27 Apr 2024, 23:37
ESPECIALLY if not charged very regularly you want a BMS that has 1A or above balance current. Then if its say jst 1A out of balance due to varying internal self disharge between cells while stored, it will be able to balance up in 1 hour at the end of charge. These BMS you linked claim 60mA balance at a microscopic REAL 25 to 50mA.. UNLESS I read it wrong! That means that at the end of charge the balancing would take 20 to 40 full hours. Not good for the other cells due to the way a BMS works, and wont actually happen because the charger will think its all charged and switch off... Also be sure it does not try to balance below 3.450V preferably 3.500V and that never allows a cell above 3.550V while charging. And it does.
So as BMS go, that one is OK as long as the battery is about the size of a laptop. Remember that your PL8 has a solid 1A or 1000mA balance capability, as well as the fact that it throttles the charge output proportionally as neeed to prevent a cell going sky high. The BMS cant do that as it cant tell the charger what to do so the cells do go sky high then the BMS chops of charge power repeatedly on/off, while the feeble 50mA balancer pulls them back down again over and over unless the charger thinks the battery is charged. Which it will. Net result is unbalanced cells. That APPEAR balanced as they can be at various states of charge while at the SAME voltage once below around 3.5v which happens when they relax and the charger is off.
Postby steves1977uk » 28 Apr 2024, 13:22
UnicornBurner wrote:Hi Steve,
Hi UnicornBurner,
I was referring to the terminal lugs you've used, as the ones I bought from Farnell the solder doesn't stick to them. :fencing And it's very hard to find M4 lugs that accepts 10mm2 wire.
Postby Burgerman » 28 Apr 2024, 14:59
If you buy copper, brass, or zinc or tin plated copper or brass, then the solder WILL stick. I never found any terminal that you cant solder.
If you are trying to "stick" melted solder to anything at all that has size or bulk such as a large cable or terminal then a soldering iron doesent work because it doesent get the materieals hot enough. You dont solder by applying melted solder to a surface. You solder by heating the cleaned fluxed parts up until THEY melt the solder as it is applied.
I normally do this with a TINNED iron, and a fluxed terminal if its a small balance wire. Or if its bigger and the iron doesent heat the connection adequately, I use a "turbo" lighter. And once hot, apply the solder and allow the flux to make the solder run into and all over the joint.
How to solder a connector properly with an iron. If its bigger than this do exactly the same thing but use a small "turbo" lighter for heat. And with bigger connectors use some flux on the wire first. Dont copy the other ham fisted retards I just watched on youtube. :shock:
youtu.be/havAF0sJjp4
Postby Burgerman » 28 Apr 2024, 15:42
And with a lighter.
But ADD some FLUX on anything bigger or it will go all black ad solder will not "stick"...
I do andersons, big battery terminals, etc this way. A small soldering iron is not man enough.
youtu.be/QCZ05-rPNR0
Postby Burgerman » 28 Apr 2024, 15:54
DONT do this. This is a typical youtube retard.
This has solder fused to the terminal. It would have fused better if he used flux. Then he heats it up and remelts it, and just stuffs a wire in! Thats a perfect way to make what we plumbers call a dry joint. The cold wire is NOT soldered at all. Its just got a bit of solder traping it in place. It will end up as a high resistance corroded joint. It may even pull out at some point. To solder the wire he should have FLUXED the wire strands, heated that up and tinned it with solder. Then appled the wire to the terminal cold. Then heated it up (the terminal) until all the heat transfered to the wire and the whole joint melted and the wire slid in. Then the whole thing would be one part all fused and solid. More solder may have needed to be added too.
HOW NOT TO DO IT. Also no crushing in vices, no taking too long and making it all overheated, no stray strands poking out, and all the other retarded stuff I just had to suffer while finding the two vids ABOVE for you. You tube amazes me. There are at least 50 wrong and retarded ones for every good one. And if you do not know any better already (and you are looking how to do it) then you cant tell the difference.
This is how NOT to do it!!!
youtu.be/UMeGCQa-oCI
Postby Raro » 28 Apr 2024, 17:52
Isn't it easier to use copper collector plates?
Raro
Postby Burgerman » 28 Apr 2024, 19:24
If flexible, yes. If not dont use them. And if bare copper dont use either. But then it doesent matter as you still got to connect cables!
Postby LROBBINS » 28 Apr 2024, 19:26
The problem with flat connector plates where there is vibration, as on a chair, is that they may fatigue crack or cause the nuts to loosen. Some flex is needed. Connector plates with a bend in the center might be OK, but wires with lugs are a "sure thing". The flat plates are OK on static systems such as for solar panels. BTW, annealed copper is soft and fairly flexible, but as it ages it gets stiff and cracks as often as it bends.
Postby UnicornBurner » 29 Apr 2024, 00:28
Hi Steve,
We also found not find the exact lug. We used size 8 wire and bought lugs with the smallest holes available for our wire.
We bought these, here in the USA. http://www.hillsdaleterminal.com/downlo ... 20ring.pdf
We used Hillsdale Terminal part # 50610.
We removed the red vinyl covers.
I would also agree with the advice given here, especially about the use of flux in soldering. Also be sure to clean the leftover flux from the terminal once you are done. We used ipa and as it cleans well.
I hope this helps you.
UnicornBurner
Postby Burgerman » 29 Apr 2024, 08:09
Ebay has many for 10sqmm cable with 5.5mm hole, or 6mm. The extra bit of slack doesent matter. Add thin washer.
Postby UnicornBurner » 29 Apr 2024, 17:11
Hi BM,
Thank you for taking the time to look into the bms I linked and for your thoughts. I shared them with my husband and he read the same as you and fully agrees with what you are suggesting.
So I am now on the hunt for a bms within the specs you recommend. You don’t happen to know of one that exists do you?
Thanks again for your help.
I will keep the group updated on our adventure in case anyone else wants to try this conversion set up.
Cheers! cheers
UnicornBurner
Postby Burgerman » 29 Apr 2024, 18:16
Not off hand. But shirley posted a link to one recently I think.
These balance at a more sensible 2A. Way better than a 50/60mA setup! BUT I dont know if they can be configured to only balance above 3.500v or if they balance all the time. Which definitely is a bad plan on lifepo4. It actually unbalances them over a days use. Makin a mess of balancing when you recharge.
https://www.fogstar.co.uk/collections/b ... e-balancer
Postby UnicornBurner » 01 May 2024, 16:16
Hi BM,
Apologies ahead of time for this stupid question, but here it goes. I was looking for “4s” BMS setups and you linked a “16s” setup. My reasoning is we have 4 sets of batteries linked + to + and - to -, so I would only need a 4s BMS. However, we do have 16 Eve 105ah batteries in total. Should I be looking for a 16s BMS instead?
Ann
UnicornBurner
Postby UnicornBurner » 01 May 2024, 16:22
Hi BM,
This one seemed promising. It seems configurable. Most pricey….of course. Thoughts?
https://www.amazon.com/gp/product/B0CMP ... A0R09&th=1
UnicornBurner
Postby Burgerman » 01 May 2024, 17:12
16s bms with a 16 cell series pack.
If you plan on connecting say 8 in series and those in parallel so you end up with 8S then you need an 8s BMS.
Postby Burgerman » 01 May 2024, 17:16
Product advantages:
Active balance, good durability, long life, good balance and stable performance
Real-time active energy transfer equalization with supercapacitor as the medium.
Single voltage range 1V~5V, equalization accuracy ±5mV
It can achieve 2-10A continuous balanced current, ensure battery consistency, improve battery cruising range, and delay battery aging.
Mobile phone BT communication, equipped with mobile APP, real-time view of battery status, support Android and IOS operating systems.
Support balanced cascading, suitable for more than 24 battery packs.
Suitable for lithium iron phosphate, ternary lithium, lithium titanate and other battery types.
JK-B2A8S20P
Package
BMS{BT bulit-in}
NOTE:Due to the different voltage ranges supported.
Therefore, among the accessories of B1A8S20P/B2A8S20P,
RS485, LCD,Able and other BMS are not common.
Power Board is the same version.
Please choose to buy them carefully. Thank you
Methods of activating the JK BMS:
1,Charger activation method: Please use a blind charger that is 4V or more than the actual voltage of the current battery and charge it to activate it.
2,Small power supply activation method: Please use a DC power supply with a piezoelectricity of not less than 4V or more (you can use two batteries in series, or use the charger of your mobile phone), connect the positive terminal of the small power supply to the B-terminus of the JKBMS and the negative terminal to the P-terminus of the JKBMS to activate it.
3, multimeter activation method: please use a digital multimeter, set the multimeter to beeping gear (to measure the on/off), connect the red meter pen to the B- terminal of JKBMS and the black meter pen to the P- terminal of JKBMS, BMS is to be activated.
PS: JKBMS activation is characterised by a flashing red LED on the BMS and two long beeps. At this point, use the JKBMS APP on the mobile phone to scan the device, i.e. the cor
APPEARS TO TRY AND BALANCE REGARDLLESS OF VOLTAGE. YOU DONT WANT THAT!
Postby shirley_hkg » 04 May 2024, 02:14
UnicornBurner wrote:This one seemed promising. It seems configurable. Most pricey….of course. Thoughts?
Not that pricey on Taobao , <$70 US.
Postby shirley_hkg » 04 May 2024, 03:00
Burgerman wrote:APPEARS TO TRY AND BALANCE REGARDLLESS OF VOLTAGE. YOU DONT WANT THAT!
No. It doesn't.
Balance Start Voltage,
Cell voltages diffidence ,
are user defined. Balance will start only when BOTH are true.
Users browsing this forum: Bing [Bot] and 355 guests
