Peak and cut off mean pulse or something like a short. If that takes as long as it takes to pop the front wheels up in order to climb a curb. Or to accelerate off a road up a street ramp it is called continious. Anything longer than approx half a second. The greater the current the faster it cuts out.
But theres more to it than this. When you have a low current 1C cell, it has a higher internal resistance. Thats why they ARE low C rate. Now the low impedance (resistance) means that the bigger the load (current) the greater the voltage drop is. So as the battery becomes more discharged, the voltage drops lower and lower. But UNDER LOAD it drops significantly and instantly and then the low global voltage BMS safety thing trips in. Or worse the individual cell low voltage trips in. Especially if the cells are not well balanced. Because then the lowest cell drops further, as you try to accelerate or draw a bigger than average load. So now its not the over 100A current that trips you up, but the low voltage limits on a cell level under load as you do something that needs amps! Obviously the becomes more and more likely as the cells discharge.
This is why a larger pack works better. And why NO protection system is wanted in a powerchair as your control system already has all this built in and controls things proportionally. No sudden trip and you stop. It simply reduces pulswidth and throttles back to not exceed the voltage and current limits. Those limits are higher than the BMS in that battery though.
You will likely find all this out in practice! Again, used gently, no BMS problems, and quality battery construction, good BMS programming, and an understanding of what I just said and it MAY work for you used gently. Rolling at high speed is no problem, this is the time that the chair takes the LOWEST amount of current. So it wont stop it rolling at max speed. Its the turning, ramps, and particularly acceleration at low to mid speed (100% pulsewidth) that give heavy battery loads. But while you may think that YOU dont do this, the MOTOR COMPENSATION will be doing exactly this in the background as you use the chair.
I get it. You just have to monitor them as you go.
What will your mnitor tell you? Battery voltage? That wont tell you anything useful.
The charger is pretty small and easy to carry and I can always plug in when I'm back in my wheelchair van.
Its not about range...
At least with the Bluetooth connection you can monitor your batteries more easily than any home build pack.
With a properly charged large pack, the whole point is that it is capable of any amount of current your chair can draw (Amps) and that theres zero need to monitor anything at all for the first 80 miles or so. And the BMS and all its inherrent problems cant trip you up and isnt required.
When charging you can see whats happening on the PC screen. If interested. And its pretty important if you want to study cell health, connections, balance, self discharge, measure capacity in and out accurately etc.
Can you do this with a 100Ah pack and a BMS? Well it will work. In your case. Probably... But you will have lost out on the reasons that we go lithium in the first place. That being incredible battery lifespan, reliability, endless range, fast charge. Charge weekly if you dont do that many miles, (remember cycles are finite so charging weekly means already lasts 7x longer!) And will give you much much more range without going anywhere near the deeply discharged stage. Hence longer lifespan again... And lower average depth of discharge, and lower current draw per Ah, - way below the battery limits also mean longer lifespan. And of course the price... You are paying way more per Ah. For small gains and potential issues and losing out on the benefits. Which is why I always say its a bad idea. But if thats what you wish to do, go for it. If no issues with BMS crop up, you will get about double the range if you ran it dead. But you must keep 20% reserve or it wont last and you wont get home... So maybe you get an additional 80% over lead.
Building a big pack and a 40 or 70A hobby charger isnt for everyone. Thats the best and most reliable bang for the buck though. To do the job right. 5x the range with reserve and many more cycles. And about the same price. Annd they are reliable!
