Burgerman wrote:Set graph to display all cells.
Burgerman wrote:Is there a reason to only charge at 10A?
Burgerman wrote:Other than the choice of computer
Burgerman wrote: begin balance at 3.40V and charge to 3.500V. But thats OK just for the first charge where it sits a long time balancing.
jefferso wrote:Burgerman wrote:The grey cable is your breaker. Add this into the loop. At the positive end.
Thanks. So I'll connect the black cable to the negative of cell 1, the short grey cable to the red cable directly (not attached to any post, maybe with a nut and bolt, then perhaps covered in insulating tape), then the long grey cable to the positive of cell 8.
How is a normal discharge done with the PL8?
What happens with the energy if there is no other battery?
Burgerman wrote:If your balance traces look odd after you connect that dont be surprised. They have a resistance across the internal contacts and bimetalic strip.
Users browsing this forum: Bing [Bot], emilevirus, jefferso, MagicJin, shirley_hkg and 68 guests
