Burgerman wrote:Whatever looks mechanically right. I wouldnt get it wet. Corrosion = all sorts of balance problems.
Burgerman wrote:Dont crimp...
Or if you do solder it as well.
Yes your cables are overkill. I just use a ring terminal and solder it same as balance wires and add a 150A MIDI fuse.
so the effective choice is between AWG 8 and AWG 10 Superchunk wrote:yeah it's a permobil so height issues are the problem more than anything.
16xeve-105 should fit though. Does the continuous discharge rating increase with capacity when wired in parallel?
Burgerman wrote:Why dont you just use metric cable?
The internet, ebay, amazon etc all have both the incomprehensible AWG sizes and metric stuff.
<SNIP>
Try that with the old imperial system. I just makes everything in engineering so much easier.
Superchunk wrote:Has anyone ever tried to put 16 cells in an 8s2p/2p8s configuration?
Was looking at the Eve-105 cells. I believe 16 could fit in my battery box, which would give me 210 Ah.
Is this a bad idea? If not, would 8s2p be better or 2p8s?
16xeve-105 should fit though. ?
shirley_hkg wrote:Superchunk wrote:yeah it's a permobil so height issues are the problem more than anything.
Too optimistic I guess.
Unless they were welded to connect with each others, they'll be 220 high, if you were using studs and lock nuts.
EVE-105 comes with shallow M4 thread hole, which is weedy. You will be extremely careful with it.
I did have poor experience with these.(2P8S)
I'd suggest to configure them in 2 X 24V packs.(1P8S) * 2
shirley_hkg wrote:160 is a lots in wheelchair sense.
You can use 140 out of it safely.
Correct me on my design bullets
. cells can be strapped together with fibreglass separators/inc bottom layer using gf packing tape (no clamping rods)
. cells must be in a convenient case with lid but line with dense foam against vibration shock.
. cells must be Z linked with flexible busbars (relieve any stress on terminals)
. a commercial charge controller may be used for monitoring cell volts and maybe blue tooth but simple metering may
also be used if the volt are kept to 3.55V/cell. OVP/cell may be done by individual audible modules
. charge supplied by a PSU with CC/CV setting
. charging not to take place unattended or overnight
. OCP by 15A Ato fuse
. OVP by PSU settings
Running use
. SCP done by 80A Maxi fuse for each battery 12V bank
. OCP done by resettable PB thermal for each battery bank
. Motor connected to controller then battery via isolation switch
. Means of motor plugged (resistive sc across terms) in event that battery becomes disconnected - prevent runaway no
braking tba?
RobinReturn to Everything Powerchair
Users browsing this forum: Bing [Bot], iansp, jehan and 183 guests
