Group 24 cells
Re: Group 24 cells
Postby shirley_hkg » 30 Aug 2024, 05:20
I'd consider a notch on the front , to route the cable out.
Here seems appropriate , as no moving parts around.
Re: Group 24 cells
Postby shirley_hkg » 30 Aug 2024, 05:35
Re: Group 24 cells
Postby Burgerman » 30 Aug 2024, 08:11
And a screw through the case (open it be sure gap so wires dont ollide!) to hold the connector flat on he surface to make it stable and easy to connect.
In the same way I did with the dual anderson connectors on he invacare storm xplore.
Re: Group 24 cells
Postby jefferso » 30 Aug 2024, 23:56
I just had to put the MK Gels back in. When I would tilt back all the way, then come back to upright, the chair went into turtle mode. The wood on the sides might have been just slightly higher than the MK Gel batteries, so it might have been somehow interfering with the tilt. Or maybe some cable wasn't fully plugged in. I don't think anything about the pack could have confused the tilt actuators so it must be something else. I just won't be able to diagnose it until later next week unfortunately. I'll cut the boards to be shorter and see if everything goes back to normal once I can get the pack back in.
jefferso
Re: Group 24 cells
Postby jefferso » 01 Sep 2024, 00:27
Burgerman wrote:And a screw through the case (open it be sure gap so wires dont ollide!) to hold the connector flat on he surface to make it stable and easy to connect.
Ah, nicely mounted. Sounds like a good idea. Maybe I'll have to get a bracket to mount the plug. And something to cover it to keep water out. Shouldn't be much direct water there under the seat where it should be protected from the rain, but could get splashed by a bus or something.
jefferso
Re: Group 24 cells
Postby Burgerman » 01 Sep 2024, 08:45
You might be able to use velcro. Cut to same shape.
And a black alloy metal backshell, and if you connect a balance lead and another plug to it to feed a
https://www.amazon.co.uk/ISDT-BattGo-Ba ... B07WZFS7D8
And heres a vid...
youtu.be/HlcYuVHTqvg
Then you cant get water in. And you can check battery.
Re: Group 24 cells
Postby shirley_hkg » 01 Sep 2024, 11:39
I injected hot glue into the connectors fully.
Can't be open.
Use the 2 stock holes .
Re: Group 24 cells
Postby Burgerman » 01 Sep 2024, 12:16
Confused. Did you shirley make that cable? :?
If so that explains...
Re: Group 24 cells
Postby Burgerman » 01 Sep 2024, 12:20
Even though when tested the cell log is pretty accurate, it can be USER CALIBRATED so that it reads exactly the same mV as your mutimeter. How to do that is documented on youtube. And its very easy.
The thing is a litle cheap lookng and plasticy But its bright, coloured, has a graphical cell level view, can be calibrated in needs be, and you can set an alarm at any cell voltage if you want. You cant see it in sunshine though.
Re: Group 24 cells
Postby shirley_hkg » 01 Sep 2024, 12:20
You are no wrong.
Why not a BMS inside , so you can see on your phone. Half the price.
Re: Group 24 cells
Postby jefferso » 01 Sep 2024, 13:15
shirley_hkg wrote:Use the 2 stock holes .
So I can unscrew the screws in the two holes and don't have to worry about it coming apart since it's glued. Then get longer screws to go through some holes in the shroud to secure it.
Burgerman wrote:Confused. Did you shirley make that cable? :?
Yes! Without which I would not have been able to attempt this project.
jefferso
Re: Group 24 cells
Postby Burgerman » 01 Sep 2024, 15:44
shirley_hkg wrote:Yes.
You are no wrong.
Easy.
I have no smart phone owned by a marketing and data mining company.
and
They take up space on the chair that is better used by ading more capacity.
And they draw small current all the time from the pack.
Mainly because fire risk caused by failed BMS.
And because after you used the cell log in week one you realise its not needed anyway. All I do now is guess. Or look at the joystick for a light out or at the mles. No danger of over discharging. So the cell log is just for initial setup and getting used to how far you can actually go.
But those are MY choices!
Those are why I dont.
Re: Group 24 cells
Postby jefferso » 01 Sep 2024, 23:08
Do you know what size those screws/bolts are in the stock holes?
jefferso
Re: Group 24 cells
Postby Burgerman » 01 Sep 2024, 23:14
Likely m2.5 or m3. On some plastic shells they are self tappers. Take out a screw and look carefully. You may need to drill it slightly bigger for say a couple of longer M3 screws or similar.
Re: Group 24 cells
Postby Superchunk » 02 Sep 2024, 23:50
Wait, what was the problem of just passing the d-sub cable from the side where there is no chassis cover? That's what I'm planning to do with my m5
Superchunk
Re: Group 24 cells
Postby Burgerman » 03 Sep 2024, 00:08
Nothing at all if you can. And if its neat and professional looking.
Re: Group 24 cells
Postby jefferso » 03 Sep 2024, 18:11
The bolt looks like M3.
The Anderson SB50 on my C500 is mounted with a little spacer made from a piece of plastic cutting board.
Maybe I'll try to do something like that. It might be nice to mount the spacer on the shroud, then have holes for the bolt so it wouldn't be necessary to have to hold the nuts from behind the shroud each time it has to be removed.
I'm leaning towards trying to mount it on the back more vs. the front because the front is hard to reach through the leg rests when the chair isn't elevated. It might be difficult to plug it in blind when reaching through the leg rest. Or an extra step to have to raise and lower to charge.
I might be able to get it to come out the side without cutting the shroud, but I'm worried it might be close to one of the springs. I wouldn't want the cable to sag onto the spring and start to wear.
jefferso
Re: Group 24 cells
Postby shirley_hkg » 04 Sep 2024, 04:31
Just in case.
Re: Group 24 cells
Postby jefferso » 11 Sep 2024, 13:48
shirley_hkg wrote:Just in case.
Thanks. Is there a plastic cover for that king of plug? Or is it a custom one that won't have something like that available?
I got a rubber one for SB50 a while ago and thought it might be nice to cover this one in case of a rainy windy day.
jefferso
Re: Group 24 cells
Postby Burgerman » 11 Sep 2024, 14:32
It is already a plastic cover. What are you hoping for this to achieve?
I use metal shell on mine but both are OK.
Re: Group 24 cells
Postby shirley_hkg » 11 Sep 2024, 14:58
jefferso wrote:Thanks. Is there a plastic cover for that king of plug? in case of a rainy windy day.
There is one in your latest parcel. Dust cover of Dsub .
Re: Group 24 cells
Postby jefferso » 12 Sep 2024, 12:10
Burgerman wrote:It is already a plastic cover. What are you hoping for this to achieve?
If the plug is mounted on the shroud, I'm worried about water getting in the plug holes in the end when I'm outside and it's raining, or dust etc.
That seems to fit, thanks. It kept popping off though, looks like the end was damaged a little in the shipping.
jefferso
Re: Group 24 cells
Postby jefferso » 12 Sep 2024, 13:03
What is that dsub called? Is it equivalent to 25 Way D-Sub?
jefferso
Re: Group 24 cells
Postby shirley_hkg » 12 Sep 2024, 13:39
I wouldn't worry about rain /damp at all. It's glued inside, so nothing can move or get into it.
It's called 21W4 here.
Re: Group 24 cells
Postby Burgerman » 12 Sep 2024, 16:37
jefferso wrote:What is that dsub called? Is it equivalent to 25 Way D-Sub?
yes.As shirley says though, its all low voltage a bit of rain will do nothing.
Re: Group 24 cells
Postby jefferso » 21 Sep 2024, 22:52
The wood I used previously was half inch (1.3cm ?) plywood. It seemed to interfere with something. Even after cutting it lower and filing the edge a bit so it fit in better it still caused the chair to go into turtle mode after returning from a full backward tilt for some reason.
I got some chopping boards at the local market for £3 each and they were just the right size to nearly match 2 group 24 batteries side by side and about 0.8cm thick (5/16 inch?). An extra piece of cardboard wedged in next to it makes it snug. Two strips of acetate screwed in at the stop keeps them upright.
The cable could go out the side, around and then up to the middle in the back, but it seemed neater to cut a notch in the shroud so it could come right up in the back in the middle. A piece of chopping board is mounted to the top of the back shroud in the middle. I had another piece under the shroud to make it extra secure but I had to remove that and even file the nuts down a bit because there wasn't enough clearance under the shroud for the circuit breaker. The M3 bolts are just threaded into the plastic of the chopping board, so I hope that holds it in place well enough.
The chair doesn't seem to go into turtle mode any more after tilting back and then forward all the way.
It's currently getting a full charge.
jefferso
Re: Group 24 cells
Postby Burgerman » 21 Sep 2024, 23:09
Very good. Did you test it out?
Re: Group 24 cells
Postby jefferso » 21 Sep 2024, 23:26
Did some seating position changes to test, all seemed fine.
Just finishing a full charge now. Will maybe take it out for a spin tomorrow, though it looks like rain tomorrow…
Here's how it looked with the charging cable coming out the side. Not terrible but this definitely looks neater.
jefferso
Re: Group 24 cells
Postby Burgerman » 22 Sep 2024, 04:15
I think you are going to be surprised how far those cells take you.
Re: Group 24 cells
Postby Superchunk » 22 Sep 2024, 14:59
Awesome, thanks for posting these updates jefferso!
I am in the same process, just a couple steps behind you!
Superchunk
Users browsing this forum: emilevirus, Jay_x, MagicJin, snaker and 109 guests
