Burgerman wrote:I would mount it on spacers to give thechairs more running clearance,
I use an RGK Hi-Lite manual chair with E-Motion wheels most of the time and in the car.
Burgerman wrote:I use an RGK Hi-Lite manual chair with E-Motion wheels most of the time and in the car.
Once you try a GOOD powerchair you will probably just throw that away... It doesent do anything better. Its wider, longer, less capable, less comfortable, less stable, less reliable, less controllable and less range/speed too...
Step wrote:I think there's a manufacturer who solved the ground-clearance problem with a magnetic pin for the EZ-lock or comparable docking stations.
If I remember well, it used an electromagnet to hold the pin inboard to have as much ground clearance as the chair allowed.
Cutting the power to the magnet let the pin drop down to catch the docking station.
Dunno how much a permanent engaged magnet would drain the battery though...
And permobil have a retractable pin system, here's an animation: http://forum.permobil.com/templates/Page.aspx?id=3214
At a permobil price of course... check out the order form http://forum.permobil.com/upload/canada/Order%20Forms/March01_2008/21_Permolock_CAN_2008_Rev2.pdf![]()
looks like it works with a small ram.
Looks like something the handymen here could come up with.
Users browsing this forum: No registered users and 28 guests
