My friend charges this way mostly, as carer always mess things up with PL8.
He charges with PL8 occasionally, to check status of battery.
Burgerman wrote:The connectors. Some are not capable of even 5A and get loose or oxydise and burn the joystiv=ck sockets and the heat causes more oxidation, rinse and repeat.
At 5A any cheap connector probably OK.
At 8A the cheap ones start to get hot after some use, and can causeburning but usually ok.
At 10A as many chair chargers now are like the permobil one that can melt the joystick socket as permobil found out to their cost when using a crap make of XLR on their charger. $$$$$.
At 12A its quite critical that you use a genuine Neutrik NC3MXX or sooner or later it is likely to get very hot and melt the joystick connector. Those are quality, and good for 16A so have a bit of reserve! Dont exceed 12A though.
An example...
https://www.wheelchairdriver.com/board/ ... =2&t=11183
wes4dbt wrote:Jeff,
It looks like the IP22 doesn't come with an output cable. I've got a couple of the IP65, It has an two wire output cable that I cut off the end and connect an XLR plug cable.
How does yours work?? Also, where did you find the XLR cable? All I could find basically was very small wire microphone cables. I've been buying cheap used wheelchair chargers from ebay and just cutting off the cable.
Thanks for any info.
jefferso wrote:Can the BMS handle more than 12A? The XLR plug has an XT connector on the other end to plug in to the XT plug on the BMS. I imagine that can handle more current than XLR but what's the limit for the BMS itself?
wes4dbt wrote:Thanks Jeff,
Thought you might have found a cable supplier I missed. I'm always hoping. lol
Burgerman wrote:Would the 230Ah (244 actual) cells have done the whole trip without charging? Presumably yes. Shame those didnt fit.
Burgerman wrote:Recharge looks perfect. Those are Docan eve cells are they not?
Burgerman wrote:It good regardless. When you consider that you only get around 35Ah if you run a set of GRP 24 lead batts until the thing stops... And return about 40.
So you returned roughly THREE complete charges for sets of grp 24 lead batteries! (120Ah) when you got home. Or 4 sets of batts overall if you include the single 40Ah charge.
Users browsing this forum: MagicJin and 73 guests
