This will continue, untill the 16 hours I selected is done. Then it will turn off.
How to go to the menus :⇒
①USER : press the menu button once.
②ADVANCE : press menu button for 4 seconds, prompted for password, (default 0000). Press again.
③FACTORY : press menu button for 4 seconds, prompted for password, (default 0000). Press 4 seconds to enter.
Raro wrote:If it's not a bother, can you make a video showing how you configure the zxd?
The develop team is ambitious and hopefully it will in the near future.
Burgerman wrote:Yes.
Theres not a need really to control it via anything unless you use it for a few different jobs/uses.
emilevirus wrote:I just received mine. It won't go past 25A. Any idea why?
LROBBINS wrote:At least on the old ones, 120 vs 220 V were not different versions, but different settings in the user-reprogrammable firmware.
Burgerman wrote:I dont know if the 25A/120v versions are the same physically as the 50A/60V versions.
I suspect they are and its just a settings thing.
In the menu inside, advanced menu, set it to 3000w, it likely already is, and to 50A and 60V instead and see what happens.
As far as AC input, they all work from 80V up to 260V or more.
it won't do that, will it? It will turn off after max. 24 hours!Return to Everything Powerchair
Users browsing this forum: emilevirus and 491 guests
