That leaves a large 8V of unused headroom.shirley_hkg wrote:
I wouldn't run at max amp.
Leave it room for long service life.
Burgerman wrote:Well you say that, but I always have. Nothing failed in years of doing it. Yes gets a bit warm. So far its never been a problem.
But will the fans ramp up if it gets hot?
Burgerman wrote:Smaller fan on my new one should need to rev faster at any given temp/output power.
Burgerman wrote:Can a fancy large screen case be fitted to my original older zxd?
Or is different firmware etc needed?
And how much would it cost?
Burgerman wrote:With Odyssey, very low impedance, it stays at 50A for maybe 15 mins bfore dropping away slowly. I doubt it would continue heating up. Will soon know as will be charging the 230Ah pack soon enough. If I charge with the 40A PL8 at 24V at the ZXD then it will draw around 45 to 48 Amps. Because battery voltage is higher than input volts, and efficiency of charger.
It should be fine though. And I expect fans to ramp up as it needs due to temp.
Do your fans speed up as it gets warmer?
Users browsing this forum: shirley_hkg and 151 guests
